garmin nuvi coordinates
jjob222
Hi all,
I have recently purchased a Garmin nuvi and the coordinates, i.e., lat/lon are slightly different to what I have found on the tracks on this site. This resulted in my missing the track by approx 10 km.
What could be wrong?
Eg. the coordinates for the promisedland gold mine near childers as given on the track info is Latitude: -25.098347
Longitude: 152.168026
the Garmin will only allow me to input : 25.09834, 152.16802, I cannot put in the extra digit or the - before the 25. I believed the extra digit was just to bring you down to within 1 or 10 meters. Could the coordinates on the track be wrong?
cheers John
I would have thought the GPS would have converted them to what ever setting ???
That wouldn't give people a choice..Usually GPS's start with Bearing Degrees and or Minutes if you need minutes and you can change it to UTM if you like..It doesn't normally come out of the box using UTM..
BILLBY
which nuva: have you bought I have been running 5000 for a couple of years great in areas with terrain not so good out in the flat lands .
what mapping are you running?
:cool:
silverpark
Hi all,
cheers John
If latitude is -, it means South. If longitude is - that means west. Just type in the coordinate and then select South.
jjob222
Hi Silverpark, that is what I have done but on the ground i am still some distance from the actual point on the map. I am thinking that the coordinates on the published track are inaccurate. My gps matches google earth whereas the track is different.
poiderav4
Ditto
I have a Rav4 with inbuilt Sat Nav, I recently was in nsw doing the lithgow to bathurst track, I wasn't strictly following any coordinates, or time lapsed. I had a map from Hema and an NRM map also a book that tells every coordinated turn and har far travelled between turns etc.
After coming up from the Turon gates there is a turn that leads to Sofala, we stopped at the sign and checked it but the coordinates on the unit did not match the coords in the book so I drove staright on and ended up nearly back onto the great western highway, we eventually turned back but even along the way we stopped a couple of times and checked the unit's coords with the maps coords and we were still wrong we found the same sign and saw that the main part of the sign was covered in a bush and with some help from a concerned local found the right way and met some oher 4wders heading the same way so all in all a great time was had and a good lesson was learned.
Peter
silverpark
Make sure you have set the correct datum. i.e. source coodinate = WGS84 datum, then set the GPS to WGS84 as well.
quinat
Garmin Nuvi
On my Garmin Nuvi there are three coordinate formats.
To change them press "Where To", then the down arrow, then "Coordinates", then "Format"
The three formats are:
h ddd.ddddd
h ddd mm.mmm'
h ddd mm ss.s'
