Galvanised Gas Cylinders
wopalx
Not sure where to ask.
Our boat was supplied with 2 x 2kg mild steel gas cylinders, which being in a marine environment they are corroding quite badly.
There are some stainless steel ones I have seen that are way overpriced (circa $400 ea) so I am keen to get a cylinder that is hot dip galvanised.
A search on the internet has not yielded any results so wondering if anyone here might have an idea?
wopalx
Thanks, my issue is physical size due to the storage bin.
Max is 310mm High and 220mm Dia.
I might call a galvanising place and see if they can blast and galvanise a new cylinder (assuming your allowed to do that and not have to have it retested).
wopalx
Yes swap and go would be ideal:)
I think I'll buy some new ones and plasti dip them, figure if I get 5 years out of them that is still cheaper than $800 in stainless steel ones.
hiluxdriver
And if they are already coroded you will need to get them blasted before paint/coating anyway. Just another expense to keep the ones you have. Swap and go seems the best idea yet - good one Gav.
Gavo
Except I'm not sure you can swap and go cylinders that small.
