If it is a big list of replacing parts/full works service, it can certainly get that high If your list is something like this:
Engine oil and filter - $100
Air filter - $80
fuel filter - $25
Spark plugs - $40
auto transmission service - $300
Diff oil (front and rear) - $100
Transfer case oil - $50
Tailshaft grease points - $50 labour, misc
Fan belts - $50
Brake fluid $35
Service labour - $400
Front wheel bearings - if replacing $350 (parts and labour) repack $150 (labour, misc)
Radius arm bushes (fairly big job) - $600 (parts and labour)
Panhard rod bushes (front and rear) - $200 (parts and labour)
Sway bar bushes (front and rear) - $200 (parts & labour)
Trailing arm bushes - $400 (parts & labour)
$3000 in that. And there's potentially more if brakes are worn, more things broken, etc. Although, after doing that list, you'd be good for quite a while.
One point, are the bushes being replaced because the mechanic has been told to, or are they actually that worn the mechanic has recommended it?
You can save a lot of money if you know someone with a trade account or a good parts store to buy your parts from, and then do most of the work yourself if you have the time (most of that list can be done with basic tools). Radius and trailing arm bushes are more involved is my understanding, but have done panhard and sway bars at home. Forums have a lot of info on DIY jobs/access to service guides.
Main difference is a mechanic, you drop it off, assuming no major problems are encountered, you get the car back a few days/1 week later. While at home, that kind of list could take a few months of working on weekends, particularly if it's new to you and need to do a fair bit of reading/asking for advice if something throws a spanner in the works (like a wheel bearing is seized onto the stub axle
, manuals don't tell you how to fix that). That's also why mechanics cost more, they have special tools/experience for the unexpected.
