Fuel Problems – Nissan Patrol 2007 Auto 3lt Diesel.
Hi All.
Has anyone experienced similar problem?
When first starting the vehicle in the mornings it will run for about 15 – 20 seconds and then stop.
I then need pump the primer pump (this model has a rubber bowl similar to that used on an outboard motor) 8 to 10 times and then crank over the motor. Could take a couple of long cranks to get it to fire. If I give it 4 or 5 pumps before I try to start the car it usually runs fine.
I can use the car all day no problems, until I leave it for 4 or 5 hours late at night or overnight and I have the same problem.
No one seems to be able to explain why it runs all day no problem, then will not start in the mornings.
Easy answer for most mechanics is get a new fuel pump. But is that the real problem? Why does it have no problem stopping and starting all day?
Any advice would be appreciated.
Michael
Hi All.
Michael
