fuel prob
AGRO JR
hi i need help i have a 85 hilux and i went to go pull my m8 out of a hole and my car cut out and when i went to start it it just keeped turning overe i found out that i had no fuel at the injectors i have been pumping the hand primer most of the day and still no fuel can someone give me some idears to get fuel up
tankbloke
Can you hear the fuel pump when the key is turned to the acc position??
I'd be also checking the fuel pump relay and the fuse.
Goodluck.
Jarh73
Goodluck.
I think you will find he has a diesel engine. No such thing as an 85 Hilux with petrol injection.
Sounds like a blocked fuel filter or given the car is now 25 years old one of the flexible hoses in the fuel system that joins to the solid fuel line has failed.
Check all the flexible hose from fuel tank to fuel filter and injection pump.
Justin
bmurray2250
Agree with the fuel filter or pump. A quick way to check is to remove the hose into the filter and put into a clean bottle. If the pump is working when you turn the key to the on position. Recommend have someone in the cab doing that while you hold the bottle and hose, it should come flowing out quickly.
Jarh73
Being a diesel I don't think that will work. The injection pump sucks fuel from the tank through the filter and into the injection pump. There is no electrical fuel pump. Majority of diesels (with some exceptions) do not rely on an electric pump (often called a lift pump) to supply fuel to the injection pump.
Your idea is perfect for fuel injected petrol engines pretty much all of which have a fuel pump in the tank.
The pumping of the hand primer as described in the original post is the most he can do. If the hand primer does not work several things could be wrong:
Hand primer Faulty
Fuel filter blocked
Fuel filter leaking
Hoses from tank to fuel filter leaking, damaged or perished.
Justin
russell789
i agree check all the lines, actually disconnect them and blow them out, replace the fuel filter and see how it goes.
if its a diesel as i suspect, i have heard you can prime them up by putting a rag over the fill point and putting in some compressed air, but i wouldnt put a lot, damage could possible be done (incase your manual primer is stuffed like mine)
