Frontera tires
mudtiera
Hi, I need new tires on my Holden frontera (jackaroo looklike) just wondering if a set of 32" or 33" will fit under on standard hieght. Thanks
baldman
you would be hard pressed to get 32's under there without a heap of scrubbing, 31's may go with a suspension tweak and I'm pretty sure that they wont scrub
Our fronty has tired suspension and we are looking at putting a 2" suspension lift through it and then trying to fit a set of 31" At's or at the most 32" and hoping for minimal scrubbing,
fronty00
Hi mate,
You will not get anything bigger than 31" under the front guards i have 2" lift and the 31"'s still scrub on the guard you need to roll the guards in at the bottom of the guard near the door if you want 33" you will need the calmini 3" lift and body lift to clear it properly
Now is a great time to get the calmini kit to as the aussie dollar is almost on par with the US and you can only order it from the US as far as i know.
I will be lifting the body on mine just an inch to clear the tyres properly until i do the calmini kit.
hope this was helpful
fronty00
As far as i know it is legal and i have not heard otherwise
I'll only be doing the body lift to give the wheels extra clearance during flex as at the moment they somtimes scrub a full flex
1" you can get away without having to mod hoses steering etc 2" you need to start making adjustments
but with the calmini you will be sweet for 31"s i know a few guys running 33's on a 3 inch lift and 2" body lift
