Front Locker or Rear
thejetstar
I have a 1993 4runner with IFS and coils in the rear. Looking to buy a locker but can only afford one a the moment. The question is in the front or in the back. It is supposed to have limited slip in the back.
Most problems I have when I go 4x4ing, up hills and on angles is one front wheel will lift, stopping all traction and I have to reverse and hit it faster or try a different line. Will a front locker fix this problem?
ratsack
I plan on going an auto locker in the rear and locker in the front. I have a 90 series Prado that has IFS. I plan on doing the rear first and if I feel like I still need more traction, I'll go an E-locker in the front.
thejetstar
I know when one wheel is in the air all the power will go to that wheel. If you had a rear locker and switched it on would the power go to rear???
dochol
Banned
If you have manual locking hub go with a Lokka locking diff. I did and was and still is the best improvement I have made to my Triton. But when you can afford rear diff lock it will turn it into an awesome 4b.
Doc
thejetstar
Want to get free wheeling hubs, is that what you mean? Whats a Lokka locking diff??? Don't really understand diff locks that well. My uncle has ARB air lockers front and rear. Still sometimes the front will spin and rear does nothing. With front and back on
darb
whatever car he has must have either a centre diff that isn't locked, or a busted transfer case. I'd say he hasn't engaged his centre diff lock, which is just a function of the transfer case really, in a "full time 4wd" system (like on landcruisers and prados etc).
in my hilux its part time 4wd, which is RWD only until i engage 4H or 4L, meaning when i put it into 4wd, its proper 4wd .. 50/50 front to back ... both axles recieve power no matter what. It's the same net result as a "centre diff lock" except to say no such definition is needed, because its part time by virtue of choosing 2H / 4H / 4L
The tradional use of the "locker" term refers at axle level, Left to Right. With my front, when locked, the both front wheels recieve equal power thats delivered to that axle.
The rear left to right depends on the circumstance the power split is variable dependin what the LSD is doing.
Open diffs have to be the most counterproductive thing with 4wd... you find the wheel that HAS traction sitting there doing nothing, while the one that has zero traction sits there spinning.
Frankly car markers should be allowed to call them 4wd if an open diff is the end result!
ashtown01
rear locker in my opinion, I have a hilux and use the rear way more than the front. The weight is on the rear 99% of the time that's where you will find traction.
all the best
darb
Yeah it's horses for courses mind you.
Every time I found myself lacking in a boggy sort of situation, I'd get out of the car, notice that both my rear wheels were doing pretty well and giving drive to both wheels (LSD) ... and it was almost always my front letting me down. THat is, id find one wheel spinning hopelessley, while the other sat there, with full traction, doing NOTHING.
So, if it's a vehicle with an open rear and open front .. yeah go for the rear first, but for myself the rear LSD is pretty good and it was always the front letting me down, so i went for front.
The other aspect was that the front being IFS (rear solid axle) seems more prone to not putting her wheels down as far (not as much flex) , meaning it was easier to find myself hung up on the front ... giving more credence to it being the front needing some help.
Obviously it'd be bloody ideal to lock the lot! (although then you have to do away with LSD and have it open when unlocked).
ashtown01
my 2010 hilux's lsd was crap. I just find u have to be very careful when using the front locker, u basically lose the front steering. I put the rear on all the time, through mud, up hills, down hills its very versatile as the front not so much.
cheers
darb
cheers
yah yah fair enough mate, there's certainly no perfect answer! LSD in mine seems great (2007). I find steering is still fine in the front when locked, but im mostly in sand (and i only really engage in really boggy terrible situations where frankly steering accurancy is least of my problem ha ha)
Hey with yours, 2010, do you have ESP/ TC? ... I thought as of 2010 they deleted the LSD altogether in favour of the TC / ESP (which is said to be great for boggy situations but in reality is actually rubbish).
Or maybe that was 2012 onward?
ashtown01
The answer is both:D I 4by the high country most of the time (only 1.5hrs away) so steep long up hills and slippery at that so steering is a must. No tc or esp, its all driver.
With both lockers the lux does well, with 32's she's not far behind the patrols and cruisers, just lacks front clearance, dam IFS!
cheers
darb
I can't stand TC / ESP crap in 4wd :) ... even ABS gives me the shits!
Problem is it's great ONroad (I've had ESP save my bacon once or twice in a 300kw rwd ute at about 100 clicks that got too tail happy in the wet over a crest when the poewr suddenly came off the rear axles) ... and even if you pull a fuse to disable it, good chance the insurance would void you in event of a prang.
(you can turn ESP off by hitting the button , but not the awful ABS).
FODFA
I would go rear first, usually you need it going uphill with more weight on the rear. Front lockers affect the steering making it harder to steer. The same question was asked at an ARB night I went to a few weeks and rear first was the answer from ARB, regardless of the vehicle.
Cheers Andrew
thejetstar
Say I was going up a hill and hit a gnarly angle and cause of the ifs the front wheel lifts. Would a rear locker get me out of trouble or would the front wheel in the air just spin?
Cheers Andrew
Hi Andrew
Any reason why he can't put a lockrite lokka on the rear and the e-locker on the front, so it can be turned on and off.
Would the e-locker being on the front effect the auto on the rear from kicking in. ?.I don't know the answer to this question do you, because when I do my Hilux that's the way id go.Unless I find more cash to get both e-lockered.:eek::eek:
FODFA
This picture was with rear locker only.
Cheers Andrew
thejetstar
I reckon an e-locker in the back sounds good. Does anyone know where to buy or how much.......don't really want to go to ARB or TJM
FODFA
Hi Andrew
For the rear, Air Locker, E locker, Auto Locker, just personal preference really. For the front a selectable locker is the go, i.e. auto lockers in the front cause heavy steering whenever in 4wd, so a selectable one like an air or E locker is the go.
I cant see how the front locker would affect the rear in anyway, a rear auto locker has the advantage of always being there, so it will kick in whenever needed, add a selectable front locker and you have a good combo.
Cheers Andrew
