from a snail to a slug hilux 5l
asho
Gday all i have a 2000 hilux with a 5l in it and i have noticed redently when i drive for long periods it feels real slow (slower than normal) and like its starving for air or something.
I did notice when it sits and idles it idles a lil high then when you go to drive it doesnt seem to rev?
Normally its a pretty punchy lil thing
My question is could my thermostat and sender be faulty
Thanjs in advance
Thermostat as in coolant thermostat? Don't see how that would be an issue, but are you thinking it's getting too hot but you don't see it on the gauge because the sender also is not working?
Could be possible I guess but the only way to know is replace them but I think the problem is likely elsewhere, if it was that bad you would likely have lost water. Could your fuel filter be due for a change?
asho
I havent thought of fuel filter i only noticed it the other day itd been running for 6odd hours and as the rain was hitting the bonnet it was steaming.
its a hard thing to describe when it does it. It revs but not past about 3500 rpm
Well thermostats don't cost much, maybe you could put one in or even just remove your existing one and have no thermostat temporarily for a time, see what happens and at least eliminate that before further investigation if still needed.
Just don't pull it apart without first getting a new gasket.
asho
Oh so can you run without a thermostat? I forgot to add aswell when it starts going funny it chews the diesel like I'm talking I did 60 kms to a quarter of a tank. Thanks heaps for the replies I don't wanna just start replacing everything I don't have the $to do that so I'll just do pieces till funds allow,I'm also due for some new glow plugs don't know if that changes everything.
Have to apologise for the spelling earlier was about 3 or so degrees fingers weren't working properly.
Yes can run with no thermostat it will just run cooler.
Apologies if you already know this, but what the thermostat does is close up & slow water circulation when the engine is cold so the engine will heat quicker. Then as things warm up the thermostat opens to allow faster flow of coolant & better cool the engine. If going up hill or towing a load or it's a real hot day causing more heat, the thermostat opens wider to allow more cooling. Thus in theory, it keeps the engine close to ideal operating temperature.
So remove the thermostat, you allow full flow of coolant 100% of the time and the engine will run cooler than normal. If the sender is working right you will see this on the temperature gauge. If you still have the low power problem, you know it is something other than the temperature.
3 degrees? Yup, been real cold here too!
oldlux
I may have missed something here but why do you suspect the thermostat and sender?
Usually lack of power is caused by blocked air filter which tends to make more black smoke than usual, exhaust restriction which makes lots of heat and smoke, blocked fuel filter which makes it gutless but not make it use more fuel or timing which should not change however long you drive it. A crook fuel pump should not make it use additional fuel either unless it has a leak?
Have you done anything to the engine, exhaust or intake at all recently?
Is there any more info you can give on the symptoms?
If it has a tubo fitted it could be that.
asho
The only reason i thought thermostat and sender was when the rain yhe other day was hitting the bonnet it was steaming yet the gauge read normal. I havent done anything to it recently except drive it for work. It doesnt blow any smoke other than a little on start up in the mornings. The fuel filter looks to be fairly new previous owner was meticulous with it.
When it does play up it revs but feels like it has a tonne of weight in it revs but stutters at about 3000 rpm.
I have a gregorys manual i have looked in there several times. Thats why i came here i might start with air and fuel filter and see what happens. Thanks for the help fellas
asho
Sorry and no turbo. Just a pain as i need the car for work as im just starting back on light duties from work cover so i really dont want to kill it and be screwed completely
Maybe a talk with the Hilux agents could be in order, might be something that can happen with them & talk to the right person they may know exactly what it is. I would visit rather than phone.
ALUX
Hey mate,
I've got a 5le hilux, same as yours but with different injection.
Sounds like a fuel problem. Id start by changing the fuel filter, and perhaps giving it a service (oil and filter). I'd also check the air filter too. These are all cheap as and won't hurt to do them anyway. Does it blow smoke? Mine was running rough so I got the timing checked and valve clearances re shimmed. This made mine run super smooth.
I would worry about the steaming bonnet. Mine has always done that. I've had other toyotas with the petrol motor do it too. Bonnet must just be close to motor in that shape.
Good luck!
asho
Sweet thanks alux ah it doesnt blow smoke at all i did get a new air and fuel filter today so will change the fuel tomorrow may even give it a service just odd its not all the time just has its moments
ALUX
Yeah cool. Could be anything but good to rule out the easy things.
2luxes
Considering the age of this car and the distance it might have traveled, I would suggest getting a diesel specialists to have a look at it. Guessing can get expensive.
Valve clearances and injectors are just some of the things that could need attention. Another is its timing belt. Do you know how old it is? It has both a distance and time limit on it. If neglected it will eventually break causing a few thousand dollars worth of damage. It won't cause your current problem unless its jumped a tooth but I am not sure if that is possible though without having the valves hit the pistons. They certainly can if it jumps a few more teeth.
Regarding your thermostat: never run without one, particularly in cold country. It evens warns about this in the genuine Toyota workshop manual for your engine. In the three degree temperatures that you mentioned, coolant in your engine will be circulating so fast it will not remain in the engine block for long enough to get your engine up to its correct operating temperature. Three quarters of the wear in any engine occurs when it is cold. Taxi engines seem to last forever because they are almost always hot. An engine doing short trips each day and spending most of the lime a little cooler than it should be will be worn out in about one quarter of the time.
asho
Good idea i wont take the thermostat out untill i replace it the car has only done 241000 so pretty low for a 2000 model but have no idea qhen the timing was last done. As said start with the simple things and slowly work it out. Funds are the big issue but little bits at a time i can afford
You guys are not 3 degrees all the time surely?
The manual recommends using a thermostat because the engine should be running at the optimum temperature and that is what the thermostat is for. Running without one permanently, would over time, cause less efficiency and more engine wear. But taking it out for a temporary period for the purpose of eliminating it as a problem is not going to kill the engine, the engine runs a bit cooler with no thermostat, but certainly not ice cold, it will still burn your hand.
However if you are concerned about temporarily running at a lower temperature you could install a new one. But as per my original post I doubt the thermostat is the problem, hence I did not see it as essential to spend money on another.
asho
I see what your saying im only goi g to pull it out to replace it i just dont want to risk damaging the engine im changing the fuel filter did the air at the shops made a lil difference but havent been for a long drive either thanks for the halp fellas
oldlux
One of the things to consider with the 5l engine is the thermostat is double ended in that it closes off the bypass as it opens to the radiator so it would not give full flow to the radiator anyway if removed and you might well find it could even run hotter without it?
asho
I didnt know that either handy to know the symptoms are odd like today when i was drive it feels like the brakes are on it just doesnt have any pull not that it had alot to start with
