Fraser Island-tire advice
bbbflash
Hi guys. Starting to think about planning a trip over Christmas time and Fraser Island is edging out Tassie at the moment. I am interested in your guys opinions about the type of tire to have for the trip. We have pretty standard Chinese made all terrain tires that were one the car when we bought them. My partners father is pretty adimate that a standard deflated road tire will do just fine all over the island, but I have my doubts. I rarely see standard tires in the mags and on the shows reporting about Fraser. What would your guys best tire to have on a stock 2004 jeep grand cherokee? Make, model, style, size, pressure...I'm all ears.
baby_troupe
A road tyre is fine for Fraser being a sand island.
Just lower your pressures to around 18psi and be careful when changing direction.
What driver training / experience do you have?
There are a few car killers on Fraser (Eli Creek for example)
Speed limit on the beach up there is 80km/h and is enforced.
I wouldn't use anything less than an All terrain tyre but that's just me...Tyre deflation is the key..Ive posted what i have posted before so you understand it a bit more...You can even go down to 10psi if your really stuck,on sand but don't spin them off the rim,take it easy.....
16-18psi is about the norm depending on the sand...
Goodluck Mate
frosty
You'll be fine of Fraser with road tyres. Sand is very coarse. Only drawback may be you'll have to adjust your pressures, maybe. On the main beach. 22-25 is fine. Indian head and further north you may heve to drop to 15-18 PSI. Inland tracks as well.
A good AT would be better, but,,, if thats all ya got, it'll do. Just don't drive to fast on low tyres with crap (chinese) tyres. Who knows what they'll do. At Xmas, it'll be as busy as central Brisvegas. Make sure you've got your own recovery gear.
The idea is dont dig in the sand, so the smoothest road tyre/slick you have is the best, so dont worry about taking road tyres they are the best for sand. I think stick to 20psi if you can any lower and when your doing 80k down the beach the tyres may get a bit warmer then ideal.
dont change direction too fast when doing 80k on the beach, it can be fatal. keep your eyes peeled for washouts. keep a sharp eye on those tourist hire 4x4's, they are often very dangerous.
Inland tracks if you find really soft sand 15psi might have to be the go.
Have fun!
nothawhiteGQ
I don't totally agree with the above post.
Sure you don't need an aggressive tyre such as a
Mud terrain for the beach but generally a large mud terrain
Will perform better in soft sand at low pressure than a road tire.
Most road tyres have a very square profile and stiffer side wall
And do not " balloon" out in the same way an all terrain
Or mud terrain do.
I believe an all terrain tyre is a better choice than a road tyre
For beach work.
If the sand gets soft don't be scared to drop pressure to 15 psi
Just make sure you DRIVE ACCORDINGLY As Slippery mentioned above.
frosty
Just remember, there is a lot of high speed beach. 80Km's/hour. Buggered if I'de be doing that with 18-20 PSI!!
BIG difference from 18 to 25 psi!!
Start at 25 ish. May have to change??
If you charge up the beach at 18 psi at 80Km/hour, you'll ruin your tyres.
krazed
Road tyres are fine in the sand ! I got a set of ht's that i let down to 17psi and its happy days in the softest of sand (20psi for regular beach driving). Only thing is when i use them i have to turn my asc off (traction control) otherwise the power cuts out sometimes . I find when my muddies are on the car works a hell of alot harder but i dont have to turn asc off . We spent a week at moreton in october on the ht's @ 18psi and not once even felt like getting closed to bogged .
Or mud terrain do.
For beach work.
I could be wrong, my understanding is, with sand you want to stay on it.
Therefore, the least aggressive tyre eg a 3mm depth bald h/t is actually the best for staying on top.
That's not to say km2 muddies are no good, ppl always saying how good they are in the sand. But a h/t is lighter and thinner also, it would have to bag just as easy or easier as it has less ply's & reinforcement.
A bald tire is less likely to dig in, therefore would stay on top longer than a more aggressive tire. If that's wrong, just explain it please????
Ohhh and rule of thumb: tyre pressure x3 = your new speed limit.
20psi 60klms/phr
MJT73
Tyre pressure is the main thing, all terrains are handy in general, but expensive if you are only making the one trip, road tyres will do the job, as everyone else has said let the pressure down to 18-20 psi, take your own recovery gear, and know where your recovery points are on your vehicle. There is usually plenty of people around to help or give advice.
03hilux
Road tyres or A/T's will be fine. Take a compressor with you if you intend on playing to the north or on the inland tracks.
I was up at Fraser in October towing a camper behind my hilux. On the main beach, i ran 25 psi, and on the inland tracks i ran 18psi.
Just watch the entry going into Eurong from the beach as the drop off the cattle grid is about 40-50cm deep. Almost everyone that went in, did so with a bang. Hopefully its been fixed.
Also, pay attention to the wash outs. Some are worse than others with Eli Creek being the worst. Generally, the further north you go, the smoother they get.
The main thing to take to Fraser is common sense and you'll have a good trip.
Thumb said :)
A few experienced 4x4ers, use that rule.
As a vehicle technician & understanding higher tyre pressures keep Tyres cooler & Visa versa I believe this is a good around about rule.
It is also my experience with many tyre types on vehicles and trailers.
If you have a look at many big 4x4 Tyres, maximum load is st maximum pressures.
Often 80psi.
There are a lot of variables, however psi x 3 is a simple rule that works.
andrewp
Great info! Do you reckon that the lack of any real need for serious tyres is the same for other areas? I am heading to Robe for the first time at Christmas and was expecting to have to change to proper ATs
(Sorry for the hijack)
Andrew
nothawhiteGQ
20psi 60klms/phr
Ok I agree with you on all of this apart from the bit about
A road tyre being a better tyre in sandy conditions :) my argument
Has nothing to do with tread type, rather the tyres construction.
And how The tyre reacts to low pressure.
In my last post I was wrong(sorry).
I said road tyres have a stiffer side wall.. Road tyres actually have a much more
" pliable" side wall to "increase comfort" yada yada..
The problem comes becouse of the difference in " pliability" (if that's even a word) between the tread and sidewall sections most of the heat is generated in this small area as the tyre distorts causing cracking and tyre failure at this point.
All terrains and mud terrains have thicker side walls and their tread in allot of cases wraps around to the side wall giving a tapering off affect to the tyre
Resulting in the heat being dispersed across the tyre more evenly.
(I did do some research there)^^^
I don't want to start another argument but you can also use your tyres to dig your way Out of boggy sand.
I think the best advice is learn to drive with what you have .
Someone with a basic setup that knows it realy well will a lot of the time
Go further than someone with a off road weapon and no skill.
Flash
You will be fine on Fraser with your tyres there's so many people there that time of year helps never far away..
I'll be there to with a bit of luck:)
Willem
Thumb said :)
Often 80psi.....
I did some pondering about this 4x4 article 5 - Tires Part 1 and totally agree ... a common mistake IMO is that people fit tough LT tires - for a good reason! - but because they are uncomfortable to drive on bitumen the owners lower the pressure below the min threshold advised by the manufacturer ... luckily the speed limits here in down under prevent them from overheating as their speed rating is - for most of those tires - well above 100 km/h...
Freedomseka
I just came back from Fraser. 1st time there. I have Kumho HT tyres. Dropped them down to 18 PSI. I have done Stockton beach and the beaches on North Stradbroke and never had a drama.
I totally agree about the washouts on Fraser. Watch out for them. That last one down the bottom before hook point was a doozee. Had about a 1mtr drop where the washout met the ocean. Had to cross up higher.
All in all, just be careful and have a go
Shano
darb
12-14psi for the win. It's what I run always on sand. Full stop. Walk out of everything.
18psi is rock hard.
** Sent from Tapatalk**
