Ford Ranger PX 3.2 XLS 2014
nananut
Ford Ranger PX 3.2 XLS 2014 (Manual)
Good Points
6 speed manual
Lots of choices for mods and accessories
Factory rear locker
Comfortable
Surprisingly easy to park even with just using the side mirrors and I've never owned a ute before
Bad Points
No headlight adjustment in the cabin
No light for cruise control when on but only has light when set
Feels like the gear stick is going to break when changing gears
What mods have you done?
Smart charger turned off!
Bosston integrated canopy with a few mods/accessories (dual tyre carriers, vent, ladder, higher 12v sockets in the canopy and a drawer)
TJM side steps
TJM bull bar
TJM side rails
TJM bash plates
TJM snorkel
Toyo AT LT 265/75R16
Kaymar rear bar with towbar (didn't like the OEM towbar location and originally wanted the MCC rear bar which wasn't available for 6-7 weeks). Had to get the pins chopped off to fit the canopy unfortunately
Bonnet protector
Long ranger fuel tank 140L
Dobinsons springs 2" with heavy duty springs and Dobinson shocks
Tinting
Locking fuel cap
Alpine double din with Alpine reversing camera and Stinger fascia kit
Rearview mirror with camera
Rhino rack pioneer tradies rack
IPF900XS spread/spot combo
Opposite Lock 2.0m awning
Icom IC450 and Benelec aerial
Dual battery system with a 200AH battery
Work lights
Runva EWX9500 Winch
Custom Installations custom drawers with MSA drop down fridge slide
FBL light strips
Mounted ARB twin air compressor behind the drawers
DBA T3 slotted rotors with Bendix 4WD pads
Battery monitor behind drawer
Anderson plug for solar panels
Custom aux fuel tank 40L
Custom water tank 50L with a water pump, switch mounted behind drawer
Solar regulator mounted behind drawer
Fuse block and circuit breaker installed behind drawers
2x double 12v sockets behind drawers
GVM upgrade to 3500kg
Inverter
Why did you buy this vehicle?
Upgrade from my X-trail and the salary packaged deal was too good to resist.
I did a month of nightly research and it was down to the D-max and Ranger.
Least mods/accessories to be done.
Every mod and accessory has a reason to be on the car.
Not going for the best looking ute but it's going to be the most practical ute.
How often do you go offroad?
Most weekends
Don't know
More photos on Dropbox. They're not in chronological order.
Wang
Looks nice you've definitely set it up well. I drove a ranger recently an really liked it even though it was only a mine spec.
nananut
Thanks Wang and Ian.
Ian, lol. Todd started the trend first when he sold his exy for a Challenger. What are you getting as you getting as your next ride?
nananut
Got the CB on and got a new Opposite Lock awning 2.0m as the old Ironman was too long. Loved the Ironman one but unfortunately no stockist in town and I can't be bothered with online ordering or going to Perth for it.
jacnden
reggie
you hear nothing but good things with the ranger , its something I am looking at.
do you do much off road ?
looks good
dennis
nananut
Cheers Dennis. So far so good. I haven't had any problems with the Ranger. I try to go out every weekend for a run. Haven't had need to use low range yet. This Sunday will be the first time the Ranger will be in low range. The thing that I don't like is all the 12V sockets in the cabin and in the canopy are constantly on even when the engine is off. So have to be careful when plugging accessories in and have to remember to take them out when engine is not running to avoid flat batteries. I'm going to have a mate install a relay for the canopy sockets so they are on when the engine is on.
nananut
Love it low range! Crawling down the hills was so slow, at some point almost came to a stand still.
This is the first time in low 1 going up a relatively easy hill. Diff lock not needed. I'm quite impressed since it's my first time in low range and in such a big car. A Patrol didn't make it up because of inexperienced and not confident driver.
nananut
Oh yea, also got a relay put in for the 12V sockets in the canopy. A fuse block was also installed to supply power to future 12V sockets by the ArkPak via an Anderson plug. 2 work lights on the back connected to a 3 way switch.
nananut
Been a bit busy setting up for the trip to SA and finally just got home. All worked well. Just need a couple of tie down rails positioned carefully so can actually tie down the gear. So addition mods/accessories are:
Upgraded the starter battery to a higher rating. Don't have pic.
Air compressor mounted and fuse block relocated to the back of the drawer system where there is a lot of unused space
Dual battery system with 200AH battery and RedArc isolator in the engine bay (no pic for the isolator)
DBA T3 Slotted Rotors with Bendix 4WD pads. This combo worked well in the X-trail so have chosen them for my Beast
Jt76
Nice ride,
Have a question re the stinger fascia kit. I have the same kit in my Ranger, but after it was fitted I tried setting the clock in the original smaller screen and it would not go into setup mode. Took it back and they couldn't get it to work either. Then during the week I fitted up electric brakes and when doing so I disconnected the battery and when I reconected the battery I tried going in to the set up mode for the top screen clock and it worked. It only worked once though. Have disconnected the battery 3 times since and each time it lets me set up the clock on the first attempt only, then it wont work again.
I wanted to ask if you have the same problem or if you can se the clock on the original smaller screen anytime by holding the mode button on the steering wheels continue ls on.
I guess its not a problem anymore as I know what to do if I do need to reset the time but it doesn't seem right to me.
Gee mate you've spent some bucks on it, it's looking good. I don't mind the TJM gear they make some great accessories.
GUnka
With that battery you should definitely run a dc-dc charger or atleast hook it up to a 240V smart charger regularly. Unless that is you're getting up around 14.4 Volts out of your alternator and as close as possible to that at the battery. Basic red-arc isolator not really the best for an AGM. I would imagine the battery wasn't cheap would be a shame to kill it so quickly.
