Quote:
Originally Posted by LowLux
Very thirsty. My friend has one and say he thanks his lucky stars he's not paying for the juice.
Quote:
Originally Posted by carves
Compared to what ??? ... fuel consumption is relevant to driving conditions, driving style, engine capacity etc ...
And what ever they get will perform the same for them as they performed in the test. Its called relativity.
Toyota Kluger is just one for you carves and for only $2K more than the Territory. How many more would you like?
A quote from Cars Guide Australia "Toyota knows that fuel thirst is a Territory's weakness and so the Kluger is more economical to run, by more than one litre per 100km".
Sambartom.
Well, I'm confused
The vehicle that is in the photo provided by Sambarton at the start of this thread is a 1998 Ford Explorer. The Explorer was the Ford U.S. replacement for the Ford Bronco II ... and was a larger vehicle making it a mid to large sized vehicle ... and with a 4.0l engine.
A Ford Territory is a Ford Aust vehicle built on a BA Ford floorpan base ... Again a large vehicle with a 4.0l engine.
A Toyota Kluger is ... from what I have seen ... a smaller vehicle, more comparable with subarus / Jeep Patriots and Honda CRVs ... and it has a 3.5l engine.
Just one ... with a matching engine size / body style / body weight etc to an Explorer.
... What reasoning would there be in comparing the Kluger with either of the other two vehicles in regards to fuel economy ... almost as pointless as comparing a prius to a V8 supercar. And whats a Territory got to do with an Explorer anyway ?????
You might want to sort out country of origin and vehicle models before worrying too much about fuel figures
... BTW ... The Aust Car Guide hype ... if 1l per 100klm is so critical to your driving needs ... Maybe you should get a mountainbike for your offroading.
Was interesting to note however, that the latest Kluger specs show very proudly - that its 2008 v6 3.5l engine uses a whole 1.5l per 100klm less than the clunky, 12yr old XJ cherokee with a spare on the roofrack, I get around in .
.... 1.5l ... WOW ... I'm so impressed with what can be done with 12yrs of technology and a smaller engine.
Bit dumb comparing factory controlled toyota specs with my actual usuage figures though I guess ... where would be the relativity in that ...
Did manage to find a comparison between the Explorer and the Kluger tho ... apparently they both suffer from rollover problems ... A change of tyre brand sorts out the Explorer ... dont know what can be done about factory fitted toyota ABS/stability control tho .......
