First Impressions – New Gasmate Butane Stoves
Yep, pretty simple.
But how many are going to ignore the 20cm thing, especially after owning it a number of years with only spasmodic use ?
Or relatives / friends that may borrow it ?
Probably not the last we'll ever hear of incidents with these stoves, but it will ost likely reduce the risks considerably over previous packaging etc.
80lover96gxl
Its more about educating users on using the right size cookware than issues with the cooker design itself imo.
As said many times before,Thousands of people have been using the old style cooker for over 10yrs without issue, saying that it's good to see the manufacturers improving the design of the cooker to help the numpties that can't work it out so they can cook safely. :rolleyes:
rogerazz
Bit like throwing petrol on the BBQ to get it going.:eek:.
Or like a bloke on the news tonight ( probably another You tube) who was pumping petrol into his car at a servo. Saw some insect near him and decided to hit it with a ciggy lighter.:eek:. And that's not all. No, not a set of steak knives.
When the bloody lot went up, he was smart enough to pull the hose out, while it was locked and still pouring petrol.:eek::eek::eek::eek::eek:
Beats fireworks on New Years.:D:D:D:D.
dirvine
I had a close look at one of these at Bunnings today. I thought the main problem was that if you put a big pan on the stove which went over or partially over where the gas can is situated, it could cause the can to heat up and then explode. I would have thought rather than a throw away template advising the appropriate size pan, why not incorporate a ridge barrier between the "giddle" plate and the gas can space that would make sitting a bigger pan on the stove not sit level? I can still see that these stoves will also explode. No one reads warnings, even when on the stove face , (as they are with my old one). So why would you continually carry around a piece of 20cm paper?
Yeah somethings fishy about the whole episode, they could have bent steel up to stop someone doing it, don't forget we have to test for the lowest common denominator of idiot...
vk1dx
I have a problem with matches. They don't have a "template". I don't know what to do. And Google wont tell me because I don't have cell access.
My god - I will starve. How useless are we getting! It was obvious to anyone with any sense not to cover the gas cover vent. And why the bloody hell would anyone NOT use the drip tray the correct way around.
I just laugh at where the human race is going. Just a bunch of thickheads. It makes me think of the humans in the animated movie Wally, where the machines did it all and they just sat back on their big fate tails. The biggest example is where the so called captain had to take manual control of the ship.
I came in late to this thread and saw a few "sensible" comments above and would like to add my tongue in cheek response.
We will still continue to use the old ones. They work perfectly when you use them properly.
A hammer doesn't come with a template - BE VERY CAREFULL!!!
Phil
Not sure about "gas (cylinder ?) cover vent" but it's definitely a reflective heat issue if the pan used goes over where the cylinder is contained.
Anyone with some lateral thinking would correlate a pressurised cylinder and excessive heat from an oversize cooking pot posing a risk, but sadly people that don't have that type of mind (and a family of 4 to cook B&E for) might not grasp it so quickly.
Anyway, time will tell as to how effective the new system is.
My brothers little gas mate cooker here has a trivet that won't allow lever lock to be engaged unless the trivet is turned over, a very good design, though I fail to see how anyone would go place a pot onto the effectively level gas burner with no airspace, even if they could.
They can't be THAT stupid, Shirley :D
Hewy54
We had 2 of the old ones, and never had a problem. However, when problems arose for others I was reluctant to use them. Bought a new Gasmate and now feel more comfortable. For the cost of $29.95 why take the slightest risk.
chris_stoffa
They are !!!!!.......................................................and stop calling me Shirley.:D ( Over ...... )
The whole withdrawal from sale / removal from shelves was about risk, insurance and liability. And trying to stop the Chronically Stoopid who walk among us from self immolating with a simple fix and a corporate proof that they can hang a court case on that clearly says "We told the dumb *****, we did, really we did, see !!
Just came back from a week away with two other users and we were and still are using the old ones.
Should there have been an Earth Shattering Kaboom:eek:........................ There was no Earth Shattering Kaboom ....................:D
Should I be disappointed ? :(
vk1dx
See the round hole about 1-2" in diameter in the top left corner of this photo. We don't cover it and use two stoves when cooking for more than two people.
Both ours have the same hole but we have a different model.
Shirley = surely!! Gotchya
Phil
chris_stoffa
See the round hole about 1-2" in diameter in the top left corner of this photo. We don't cover it and use two stoves when cooking for more than two people. Phil
That's a dual function Stickya finger in and a lookiesee type of hole............... I'd be very surprised if it has a heat dissipating function ,they just arent that technical I reckon.
mac_man_luke
Funny thing is my older cooker the gas cylinder used to get extremely cold so i would leave the door open to keep it from freezing but that cooker was never very good and didn't get real hot.
Replaced it a little while ago and the new one cooks much hotter but the cylinder does get warm so i always keep the door shut and pan away from it.
Guessing the regulators were behaving differently.
