345 chippy
firstly i would like this not to be a debate on having beadlocks.
its a sore topic with a lot of people, i know!
THIS IS ABOUT BALANCING
but after driving again this week end ,i got asked again about balancing isues so i thought this could help with the guys that have them.
what i do before fitting the external beed is put roughly 25ml(in measuring cup) worth of 4mm stainless ball bearings into each tyre.
its about $40 worth for 5 tyres. then fit the external ring.
there is no noise and yes they do end up clumping. mine are due to b replaced now after aprox 1 year.(just ordered thursday from bearing shop $44)
it does work, as you guys know that run symex or similar when you loose a bit of rubber off the side its like dropping wheel weights.
hope this little bit of info helps some of you.
happy trails 345 chippy
