Enigine color
logitech
Engine color
so having not pulled apart many engines in my life, i was curious to see the inside of the challenger is a nice brown color.
Obvisously this is oil staining but i would have thought it would have move of a silver tinge? Should i be running some product into the engine to do a bit of a flush?
mrtriton
That looks pretty clean to me but if ur concerned u could put a engine flush through it but u will have to do a oil change
Big Rig
Stop being paranoid. It's not a Nissan, that colour is fine and normal as o said when you sent me the text.
logitech
Did you just say it, or did you reply ( reply must still be coming). I know you live close, but if you just said it, no way i would have heard it.
Yeah i am paranoid but someone has to be.
Always hard to be certain by going on pictures but - that looks ok - no sludge build up .
recommend every oil change use a quality oil system flush - use quality engine oil - keep the oil chanegs to evry 10,000kms and should stay that colour
logitech
Excellent, Thanks Everyone.
Now the ******* of a job to put it back together and hopefully no more oil leaks.
bmurray2250
All the engines I have worked on looks that way. If there is no build up of deposits and metal, then it is AOK. I used a additive to clean the engine on the first oil change. The oil looked back but onto the 3rd oil change and everything looks good. I am using the Penrite 20W-60 HPR 30 - Penrite Oil and having no issues with oil usage.
profoto
Friend of mine teaches mechanics in the Army and is also involved in a lot of product research, the one thing he stresses is to choose an oil and stick with and don't change brands on a regular basis.
He maintains that additives can react with other brands additives and over time can have some detrimental results.
I use Penrite HPR Diesel 15 semi synthetic which I am happy with, the ADF use Shell.
One excercise they go through every year is running Mack engines on the redline until they commit suicide, it shows which oils last and creates about 8 engines for the trainees to rebuild.
Going up
This is great stuff!
I'm a decent mechanic, but not by trade. However, my mechanic says same as many here, use a good oil and stick with it. He only differs on the flush. He said in most cases the flush can actually cause problems, and only serves to enrich those who make and sell the flush. The picture of your engine looks like every one I've ever cracked. No worries.
