engine troubles...
reecem27
Hey guys (and the others)...
I have a few small problems I would like to fix up on my triton.
I'll go through them in order of concern...
1. If I put the engine under load during acceleration (eg. up a hill in 4th gear on the highway) it seems to stutter or hesitate and eventually (albeit gradually) does what i want it to... not good if i pull out to overtake a b-double and the engine gets stage fright.
This is also very prevalent in 4L 2nd gear when i'm off road... not the best when i'm climbing rocky hills.
I thought maybe it's a dirty fuel filter, bad sparkies or leads. The last two are not easy things to replace on this engine. Any other suggestions as to what it could be?
2. I have a bit of a fuel and burnt oil smell when the car comes to a stop, especially after i've been off road or up the beach and it's been pushed hard. I notice there is oil on the manifold and engine block, but it doesn't seem to be going through oil and the colour and smell stay fairly consistent over a month or so.
3. This one is new... I have a strange smell when decelerating, kind of like exhaust fumes, kind of like unburnt fuel, but i can't really put my finger on it and describe it too well.
It only happens when i gear down for braking rather than using ye' olde' kinetics... It even happens if i'm at high revs (5th @ 120kmph) and just throttle off. There is no popping or crackling sound that you'd usually associate with an exhaust leak or hairline fracture in the pipe. This smell is only in the cab, doesn't happen if i use aircon, still comes if i've got the air vents on recirc.
Any ideas?
4. Last of all... could be an easy one.
Bit of a shudder in the brake pedal and steering wheel when braking hard or at the end of long use.
Other than these, the car runs really well. Offroad and on.
In case you are wondering, it's the 99 model V6 3L petrol with a Manual box. 185,000kms
I've had it for 9 months and am the 3rd owner. Regular services in it's younger days... not so much lately.
NIAL8R
#1 could be dirty air filter causing it to get the stage fright when you go to put the hammer down and also could be a dirty fuel filter! what the air filter like ??
#2 check for fuel leaks. it might be hard to find if it is only a dribble here and there from one of the lines ?
#3 Q 3 might might/could be related to #2 ??
#4 could be getting close to getting the disks machined. check them out and see how badly they are marked. i would also say could be due to worn suspension components but you say its only happening after long use ! but it wouldnt hurt to check it over anyway cuase ya just never know :D
hope this may help ??
millsy
For #4 try cleaning your discs with brake cleaner, or even degreaser from the pressure pack. You need to wash the brake cleaner, or degreaser off with water, because these chemicals affect the brake pads also.
I had a problem a few weeks ago where I had really bad shakes in the steering wheel, and I think pedal shudder ( not sure, my memory is not the best, but definitely big steering shudder. )
I was thinking discs need machining, but then realized it was the kero that I had used to clean around the free wheeling hubs. I had splashed some onto the discs. Chemical reaction with pads - sticky pads - shudder and shake! Cleaned the discs just by squirting degreaser through the rim holes and hosing off. Shudder and shake gone! really should have taken the wheel off and done it properly, since I could just wash one side of the discs with the wheel still on.
My wifes car has the same problem. Really must give her discs a good cleaning this weekend. Its been like that for over a year. i thoughr I had not fitted the new pads properly, and maybe left the anti-rattle clip under the caliper instead of over the edge where it should be. Now I know why there is a product called brake cleaner in a can!!:D
MudPlugger
make sure your cat convertor has no holes in it (eg from oil dripping and burning on it). Don't sell these much (wrecking yard) but get a lot of orders for air flow sensors for Mitsubishi's and exhaust manifolds (cracked underneath). Just things I pickup through work when talking to our mechanics /dismantlers and customers (mechs, auto elecs etc)
Also sell lots of 3.0 v6 motors but not so much in the triton and challenger range, more Páj's and magnas. hope this helps!!!!
