engine almost stalls when i remove oil cap
bigred80series
hey guys
i recently bought an 80 series 1993 1fz-fe , about a month ago i started noticing a slight knock from the engine which sounds louder from underneath. i past by a few mechanics and asked them to listen to it, i got different answers some said its fine,one says bottom end, another says valves. when i rev the engine it gets a little louder but stops or gets harder to hear at about 3000 rpm's. i also noticed that the motor shakes as if its on the verge of stalling as soon as i remove the oil cap after a bit it goes back to normal.
the motor has 364000 k's on the clock
oil im using is 20w50 (1 mechanic told me the oil was too thick so i changed it to 15 40 but still no change)
i need help with this problem... its really starting to bother me.
