The thing that usually goes in them is the plasic "cog/spool" on the regulator itself which has windings of the metal cable wrapped around and around inside it
After a bit of age and cable stretch etc the cable eventually jumps across its plastic guides and across the other lines of cable destroying the plastic guides and binding onto the other windings of cable causing more stretch on the cable itself until it gets completely stuck or the cable windings will come right out of its container for the same effect.
Once the plastic guides are stuffed the cable will no longer wind around the spool niceley and instead jumps across other bits of cable adjacent to it causing binding (replacement time)
I dont think offroading would affect it too much - just age as it wears and the cable stretches over time (you can help make them last longer by adjusting as neccessary when required, usually you notice the window tilts forwards or backwards and wont track straight - classic sign of worn regulator which needs replacing or perhaps only adjusting)
My electric reg is curently stuffed, it binded inside the plastic container containing the plastic cog and spat itself out sideways kinking the steel cable which meant the cable would no longer stay inside its guides and chewed the plastic guides out quicksmart rendering it destroyed - I got a lump of wood installed inside the door trim at the moment to keep the window up
Used to replace alot of window regs at the caryard I used to work at - The whole job from start to finish (door trim off, unbolt old regulator from glass, drill/undo old regulator assembly and remove, repeat in reverse with new regulator) takes about 30minutes - We used to get rebuilt ones from a wreckers which included the bolts and nuts you need (the original regulator may be pop rivetted in depending on what car your in you may have to drill the rivets to remove the window reg first)
Only my opinion but theres not too much "moving parts" that goes wrong with them excepting the stupid plastic cog inside the window reg assembly itself Ive found after replacing dozens and dozens of the bloody things lols (ignoring electrical issues - sometimes the switches themselves have a bad contact and can cause issues also - contact cleaner time in that case)
