El cheapo Sand flag - suggestions?
Patriot
Administrator
Hey everyone,
What is everyones suggestion for a cheapo Sand Flag. I don't have a bull br, so looking for something quick and easy.
What have you used?
Thanks,
James
Pure Yobbo
Hey everyone,
What have you used?
Thanks,
James
Frosty used a 'G' Banger strapped to a pole at Stockton :eek::eek:
Can you get a cheap one that clicks into position and screw the mount to the corner of the tray? failing that a chunky piece of 50 x 50 alli angle screwed behind the front number plate and use that as a mount for something long and thin....
Bunnings, a half length of Orange electrical conduit and a $2 safety flag you normally use on long loads
Duct tape and cable ties
muffin man
what Alby said and gopher flags are good to mount on a roof rack. They don't meet the new Simpson standards though.
Patriot also you can utilise the bell end joiner on the conduit in the centre to collapse the flag in half for easier storage and just wrap join with duct tape when you erect it
Grumpy
We just use old fiberglass tent poles with the elastic cord through them so as they collapse down to about 600 mm long when not in use with a flag on the top.
Ziggy
My 4WD instructor has been using this for some 20 years supplied to his students: length of conduit with a red fabric square fixed on with electrical tape. Cable tied to the bull bar.
Ziggy
For info here's the specs for the Simpson flags:
Flag:
Minimum 300mm wide by 290mm high
Made of fluorescent materials, red-orange or lime-yellow in colour
Vehicles:
With front bulbar - flag pole attached to the bulbar, with top of the flag a minimum 3.5 metres from the ground
Without front bulbar - flag pole attached via bracket at the front of the vehicle, with top of the flag a minimum 3.5 metres from the ground; alternatively flag pole attached to the front of the roof rack, with top of the flag a minimum 2 metres from the roof of vehicle
Motorbikes:
Safety flag currently exempt however headlights must be kept on at all times during travel
Simpson Desert Conservation Park and Regional Reserve - National Parks South Australia
chris_stoffa
If you can find them the poles out of advertising feather flags are perfect - fiberglass , the aluminium ones are pre-curved so not suitable.
11.5 ft or 15 ft generally. you can get 4.5 mts carbon fibre ones if you are keen
Sourced from either Ebay or maybe from a store / advertiser that no longer uses them
Collapsible ones ( Bali Flag Poles) - 450cm Telescopic Bali Flag Pole Suitable FOR 3M OR 4M Flags MJ003 | eBay
Or the full length ones - 1X Coffee Feather Swooper Flag 1POLE 1CROSS Base 4 5 Meter Tall | eBay
ULost2
What is everyones suggestion for a cheapo Sand Flag. I don't have a bull bar, so looking for something quick and easy.
I have often wondered how are flags mounted if there is not bar
always thought a fishing rod with be a good but I bet we would be expected to have a fishing licence also :( If fishing gear is in a vehicle while in NSW we need a fishing licence; even if not using it!
maybe mounting a holder (??) onto the roof bars.......bit of pipe (??) and a roll of gaffa tape and cable ties! (??)
Neat hole in the bonnet :eek: A geo's pick would work ok :eek:
deepop
I use a flag on a pole of conduit electrical tubing.
Warning - I was told the orange conduit is for underground and is not UV protected so will get brittle quickly. Get the gray stuff.
It will last a good few years before degrading. I think you will find that the orange one has a heavier wall thickness and will stand up better than the grey
