EGR Blocked
RoughNReady
Thought I'd be one of the cool kids and post an EGR question here.
Mine's actually kind of the opposite. My 4x4 (Lada Niva) has it's EGR blocked off because... well it's complicated. I've gone through and found all the weird and wonderful things going on around the engine that were causing the EGR to operate like a game of roulette.
First of all, I'm wondering if having the EGR blocked is causing the engine to run really rich. I've rebuilt the carburettor, replaced a decent amount of parts but still have the idle mixture screw bottomed out.
If I do remove the plate there's another issue. The gasket crumbled and they are NLA. What an I use? The EGR is attached to the exhaust manifold so it gets pretty hot.
Plan B is just remove the carburettor and nick the Holley from the VW, fab a linkage, re jet it and go with it. It wouldn't be so good on extreme angles but there isn't a hill within a couple of hours of here.
Ideas or input would be appreciated.
Chatty
Wow, a question about carburetors...
Do cars still have them? :p
Stirring those brain cells which haven't succumbed to Red wine attack, I'm trying to remember about EGR and carbs...
I would have thought that the EGR shouldn't affect idle mixture, because it shouldn't be open at idle - from memory it should only open when there is sufficient vacuum, such as under acceleration or on closed throttle when decelerating.
When the EGR is open it will reduce air flow through the carb (slightly) as it replaces some air with exhaust gas, but in theory the carb should adjust mixture to the air flow, but if your mixture is as rich as you say, I don't think the EGR is causing it.
How's you PCV valve? Faulty PCV will cause mixture issues.
Paddler Ed
What Fiat engine is it based on? That may be another source for a gasket, otherwise what about a paper gasket and cut to size?
Chatty
Another thought might be floats and needles in the fuel bowl - if the float isn't, well, floating :rolleyes: and/or the needle isn't closing you will get flooding which can manifest as really rich running without the problem being bad enough to cause flooding.
Dammit, it is a really, really long time since I've had to play with carbies - and the last ones I played with were on my son's bike.
RoughNReady
Sorry I haven't been around in a while. Didn't abandon the thread. Just been busy etc.
I rebuilt the carburettor a while back and found a whole pile of things I wasn't happy with which I of course sorted. Crumbled membranes, missing spring, mangled idle jet etc. Everything replaced and it didn't make a massive difference. The float was still a float and not an anchor. Needle and seat I replaced (two or three times. Long story. Just because something fits doesn't mean it's right), float level is fine, jets are all clean, idle solenoid "works" (but makes no difference to the idle!!!) etc.
I was wondering if perhaps the loss of the gases flowing back into the manifold when the engine is warm would have caused an overly rich condition at idle.
