I tried out my new winch today, a cheapie off Ebay. Here's a link to the add http://www.ebay.com.au/itm/13000LBS...284253?hash=item56685f9ddd:g:1CoAAOSwPv9XMFqX
I have owned 2 winches previously, the old hand powered 2 tonne type, but I'm a bit over them so thought that it was time to buy a luxury electric model. There is a 12 month warranty offered, but I didn't bother reading the fine print so I'm not sure how extensive it is.
I bribed my son into fitting the winch for me by offering to buy him one too. (ya gotta love a good tax return)
The roobar that came with my fourby doesn't have a manufacturers sticker on it so I don't know which brand it is, and I wasn't impressed by the lightweight design,(although it did come with the winch bolt pattern holes and a fairlead slot already cut into it) so he braced it with 10mm plate and a few well placed gussets, which probably added on about 10-15 kilo's on top of the 30 something kilo's of the winch. The extra combined weight over the front end of the car makes for a smoother ride so that's a bonus!
The only problem we found with the kit was the size of the small allen head bolt that is supposed to hold the rope onto the side of the winch drum, it was too short to go through the rope's metal crimp properly, and would have been holding by 2 threads at the most, so he replaced it with a proper sized bolt and then carefully ground most of the head off it so that it wouldn't catch or tear the rope.
The first time I used it I pulled out a bogged 4wd tractor from a local paddock, it did the job easily enough, although I had to anchor my vehicle with another to stop mine sliding forward even though I had my foot on the brake, so there was a decent load to pull.
The first 30-45 seconds of winching nearly took my virtually brand new 700cca battery down to 11 volts, and that was with the motor idling at 1000 revs, the tractors wheels had dug into the ground about half a metre, but once it was out of the ruts the winch motor sped up some. I decided to idle the engine higher to get more charge going to the battery, so I took the revs up to 1600 which worked a lot better and gave the winch more go juice. The rope didn't wind onto the winch drum very evenly, so after we had winched the tractor 20 metres we removed an extension strap from the line, and spooled out the line and started with about 7 turns of rope on the drum, there's only so much room behind the roo bar and I didn't want to damage the rope by letting it rub on anything.
Once the tractor got onto some higher ground and actually got some traction, we unhooked the winch cable and wound it back in under slight tension, and then after another 10 minutes of fast idling and a 2 minute drive home, the battery was showing 13 volts. I put a small battery charger on it and the battery was only taking 1-2 amps, so was virtually recharged.(which was surprising since the alternator is only a 40 amp stocky) Winch run time was a good 10 minutes all up, but there was a 5 minute break when the extension strap was removed. I put my hand onto the winch motor during this break and it was warm, but not hot. I'm pretty happy with it so far, I have no idea how long it will last, but it has paid for itself already, as getting a tow/winch truck out to my location doesn't leave much change from $500. Shit, I've written a small novel lol, I'll updatethis post when I finally break it!
Here's some Iphone video
