Easy beginner Tracks with an AWD
#1
Hi, new to 4x4 Earth and to 4x4 in general. Just bought a Suzuki SX4 and am hanging to do a bit of 'off-roading'. I'm looking for some easy tracks, as I'm not sure what the little SX4 can handle. Something like an easy unsealed track to help me figure out what the SX4 can do. Saw a few track descriptions like the 'Blue Range Road - Bunyip State Forest', and 'Wombat State Forest -Fingerpost rd' but was a little hesitant since I've never done any off-roading what so ever, and am looking to head out alone with a stock SX4 and no real equipment.
Any good beginner tracks an advice would be greatly appreciated. Anything around 1.5 - 2 hours out Melbourne is fine.
Thanks
Daniel
jacnden
lots of dirt roads thru wombat forest. you could come out of bacchus marsh and onto blue gums track and obriens rd and end up at blackwood. somewhere for you to start. there are rougher tracks running of obriens to explore. just take it easy ,you dont have much clearance. there is a good adventure map of wombat forest available
tankbloke
Gidday Daniel. Welcome aboard.:)
Mt Dissapointment has a lot of easy tracks/roads that would suit.
There are also slightly more challenging tracks that you could build up to and safely find your vehicles limits.
#5
Thank you all for the suggestions, and the warm welcome.
Where do you get the maps mentioned from?
dno67
Have a read through the Vic trip report section, you should find some tracks info in there. Bunyip might also be worth a look as they've recently graded a lot out that way, poke you nose down a track
or two and have a look if it looks to hard just turn around or walk it first before having a slow crack.
Make sure you take a camera so you can share the pics with us.
#7
Thanks for all the ideas and suggestions guy. Went for a very easy drive to the You Yangs and did the Grand Circle track. Pretty much just a dirty road. A few climbs, nothing special. Was 12kms all up. Was a nice starter I :)
Definitely more to come :)
#8
Hi
Welcome aboard mate, being new and no recovery gear and all alone with little experience I somehow think it will end in tears, you maybe lucky but a bit of rain and its most likely to run out..
Especially visiting areas like Bunyip, Noojee, Wombat with its Sticky clay mud and deep ruts I would at least suggest you go with someone who has knowledge of the area and decent recovery gear...
Don't forget a rooftop map of the area and compass at least. Look into tyre pressures also, letting them down, there is a thread for newbies which is a good read..
Goodluck :);)
#9
Hi
Goodluck :);)
Thanks for the info Swaggie. Seems like good advice. That's kind of why I've been a little hesitant in going, and was just looking for an easy unsealed road. Will definitely read up on it, and see if I can tag along on some easy trips.
Cheers again
jacnden
just a point on the wombat forest. bluegum track is really just a rough 2wd road and obriens rd is a dirt road. but they will give you a look into the area.
#11
Thanks for the info Jacnden.
I just checked out google maps to see how to get there, and what track I could do, going by the ones you mentioned. I came up with the following. Not sure if it's all accessible with the little SX4.
  1. Coming off Bacchus Marsh - Gisborne Road on to Russels Rd
  2. Turn on to Lerderburg Gorge Rd
  3. Turn on to Cameron Rd to get to Bluegum Track
  4. Take Bluegum Track all the way up to O'Briens Track leading to O'Briens Rd
  5. Follow O'Briens Rd all the way, over O'Briens Crossing and come to Greendale Trentham Forest Rd
Is that all accessible with the SX4? Any parts that may cause me problems? I can't add an image as yet, as I have not reached the minimum amount of posts yet, so I'll send a link to the image in another reply. Should meet my quota after this.
Any advice would be greatly appreciated...Need to plan my next trip for next weekend :)
jacnden
Gisborne rd
Russell rd
seereys rd
camerons rd
bluegum tk
obriens rd
all very easy but it will give you an idea.go into blackwood, nice little town.
if you get adventurous , diggers, xl, and ambers run of obriens rd
good luck and let us know how you go
#15
Just did Blue range rd and Bunyip ridge track at Bunyip in the xtrail yesterday, i think Blue range rd would be suitable but the ridge track is quite steep with conservation mounds. I just got through even with my spring lift with only a couple of scrapes.
#16
Hello Dazzo,
My best advice would be to book in for a 4x4 course.Which we will teach you the limitations of your car and yourself as in confidence.Under controlled conditions and instruction;)
Pending that?There are some very easy tracks in "WOMBAT"and some hard.
Happy to go for a drive. Just need to Google what an SX4 is:rolleyes:
#17
Hello Dazzo,
LOL @ Lost 2! Yeah I hadn't known that the SX4 even existed till a couple of weeks ago, when I went looking for a second car.
I'm interested in doing a 4x4 course. Would you know any that you'd recommend?
Will keep you in mind when I look to head out for a drive. What 4x4 do you have?
#18
xTrailer Just had a quick look on Google Maps, and Blue Range Road doesn't look like it leads to any other road. Looks like you'd have to track back the same road, unless you take that Ridge Track you mention. Or am I mistaken?
