dual cab roof rack mounting
ted85
Hi guys, got a dual cab with one carry bar on the cab. Wanted to put rack across this and onto the top of tray back. Would this be an issue at all? Wondering if there would be any flex between the cab and tray? Rack would not be carrying any weight except an awning...
Yes you do get some flex depending on the tracks. Maybe put some rubber between the rack and the roof rack.
Goodluck
ted85
Thats what I was thinking. If I pad out the mounts so they have a little give in them I'm hoping it'll be OK.
Tink
Not sure about a 93 Nav but way too much flex on my Dmax as the cab is mounted on antivibration rubber blocks. Go for a drive on some corrugations and look in the side rear view as to what the tray is doing compared to the cab. Will give you a bit of an idea how much it is flexing.
ted85
I might see how it goes for a week or so, if it's looking like its moving about I might need to revisit my rack setup...
Eightyeight
I've seen a D22 wreck its roof, panels and sheer bolts on a "shared" rack.
It's bad news. Too much movement by themselves, then put weight + inertia and harsh vibrations will break something. Too much movement on my colorado.
An over hang rack may be the go
Checkout my ride in My Colorado build Thread!!!
Aaron Schubert
Yeah, I wouldn't be doing it. They leave about 25mm in between the tub/tray and the body, because they flex independently.
If you tie them together, something is going to break
Aaron
I should have mentioned I had a roofrack made so all the weight is on my tubs at the rear, with a bit hanging over the roof area, it's great you can walk on it no probs.
ted85
Swaggie I'm gonna do the same I reckon. If I set roof rack between the rear carry frame and frame behind the cab it will all be on the tray. Should remove any issues involving the roof mounted carry bar... Cheers guys
Yeah Kool, I had mine made by Lowline but they closed shop at Xmas.. I also didn't want to drill holes in my ARB canopy to fit ARB roofracks.. :eek:
Here's a pic, the quotes are from the awning review..
Goodluck with it.. ;)
Buxter
ted85
This is what I did to the Navara in 2004
Buxter
Fantastic...looks good. Same idea, only yours much better than mine will be haha...
Cheers Mate !
It made a gr8 shooting rack as well.
Made from light gal pipe, and I just bent it all up in the Mates business, one afternoon, as part of some payback, for other favors done. When finished he put the best welder in the place, on it, and the rest is history.
And 2 more looks, from different angles
ted85
Cheers Mate !
This is what I'm working with, need to put that frame in rear of tray and slide while thing back.
Pure Yobbo
is that a track system on the roof? If so if you can work out the brand post up around the place you are looking for a second rack. There will be heaps around most people with duel cabs only run the 1 rack - bit like yours is now. This will work providing you want the weight over the cab and not the tray, if you want it over the tray another option will be to just make a rear ladder rack and span the roof rack between the ladder rack and the head board. Rear racks are pretty easy I made one on my falcon it will be back Saturday I could take a pic then for you
Buxter
What I have seen is a piece of flat steel bolted to the floor, to spread the weight, and the roof rack extension attached to that, with an "R" pin.
Dion80
Hi guys, new on here.... Just wondering if anyone has some input, have a 2006 Mazda bravo and want to put a rtt(roof top tent) on it but the problem I have is he roof has no gutter on it to mount roof racks, I currently have rhino 2500 vortex bars on the roof which I believe are rated at 50kg but no good for offroading with a rtt,any suggestions would be appreciated, I am looking down the path of mounting track rails but thought I'd ask first,please help
Is it a dual cab ????
. . . and is it above the actual cab you are talking about the mounting ?
Is the tub open, or do you also have a canopy ? (Preferably with internal bars in place.)
If it's an open tub with no canopy, you can fairly easily / economically make a framework for the tub so you can have a tent behind the rear of the cab.
