dual battery
mighty
Hi Guys,
I'm installing a dual battery system in my Landcruiser 80 series.
the auxiliary battery will have to support fridge, uhf radio and winch. I have a spare battery but it's a Cold Cracking Amp.
Do you recommend a CCA or should I opt for a deep cycle straight away?
As I have this near brand new battery I would like to save some $ to invest in some other mod. I'm aware that I will have to replace with a deep cycle later
Thanks in advance for any advice
4runnerSteve
You can use a standard starter battery and it will work, but your gonna kill it fast. I would put that battery on a float charger to keep it good for when your starter battery dies, and grab a deep cycle, or better yet a marine battery. They usually have a few less amp hours but high CCA's and are tough as nails.
mickley
You will have to connect the winch to your start battery and have your engine running when using the winch
That's it, don't connect the winch to the auxiliary as the main winch battery, although my TJM in cab monitor allows me to connect the main and auxiliary while winching. It disconnects after about 30 minutes, just press the button again if needed longer..
