LooneyLou
Hey y'all!
I'm trying to install a dual battery system in my truck so I can run a fan and have a couple outlets in my camper set up.
I'm using the dual battery and isolator kit from Keyline Chargers (linked bellow if you'd like to look at it).
https://www.keylinechargers.com/pro...line-chargers-iso-pro140-pro-dual-battery-kit
The second battery is a dual purpose AGM duracell platinum battery. I also installed a couple of 150 amp fuses close to both batteries as an extra safety precaution.
Everything is set up and seems like it should be working properly. The second battery ground is solid. I turn my truck on, the red light on the isolator comes on (which indicates both batteries should be charging from the alternator) but when I measure the voltage on the second battery it doesn't read above 12.5ish volts. When I take the positive cable off and measure the voltage to that (positive probe of the voltage meter touching the lug at the end of the positive cable, negative probe on the negative terminal of the battery) it reads above 13 volts. So it seems like the proper voltage is getting to the cable but for some reason it's not charging the battery when it's attached.
I have not attached a power convertor or any accessories to the second battery yet because I wanted to make sure it was working first.
I thought maybe the charge was just happening slowly, but I drove my truck around for about an hour today and it still didn't read above 12.5ish volts. I can't find any similar issues on any forums anywhere else. And the customer support person at Keyline is as stumped as I am!
What do you think?
What do you think?
