Dual Battery Systems
rangernicko
looking at getting a dual battery system maybe in a couple of months. just wanted to see what everyone else has like which brand and what system that they use. Im looking at having something where i can sit a camp for a few days and have no drama running a fridge and camp lighting. when i have more funds maybe even adding some solar power as well. thanks
Depending on your specific situation and how often you wish to run your vehicle to recharge, look at between 120 and 150 Ah and you should get the two days your after without discharging the battery too much.
hiluxdriver
Make your own system mate and install it yourself, it's very satisfying when you use something you built. Do a thread search and look in the DIY section, there is plenty of info here.
Colinp
Just about to fit a Dual battry set up in mine, doing it myself, part of the fun, not looking forward to getting underneath and running the wires.
Have purchased a Redarc BcDc 1225 with solar option for the rear tub, using the redarc RK1260 relay setup for the solar panel connection for the battery in the rear tub with circuit breakers etc
Also running a anderson plug to rear for the new camper trailer which also has a smart charger/solar connection as well and 100amp deep cycle battery.
I am doing it myself and sorted the set up etc its all sitting on the kitchen table ready to go, I just read alot of different threads and also contacted Redarc re what charger was required due to the conflicting information re alternators.
also fitting the new Towpro electric trailer brake controller will do all the same time.
rangernicko
thanks for all the feed back guys. i have heard only good things about redarc so might look into what they have to offer
Gavo
I've mentioned this before in dual battery questions, so why not again :cool:
I've been blown away with how well my ctek 250s dc to dc works.
Paired with a good agm battery my life of 12v has changed. Just my drive to and from work (25 mins each way) is comfortably enough to keep my battery basically 100% with fridge running all day everyday.
Isolators are cheap and do work. How ever using a smart charger to charge your battery makes more sense than using alternator. The ctek uses 5 stage charging so that your battery is charged properly each time.
Here's a link to their website of the one i bought http://www.ctek.com/au/en/chargers/D250S DUAL
Can be had for just over $200 on the interwebs
Good luck which every way you go. But as others have said, I also believe the kits are expensive. It's a pretty straight forward diy.
+1 for the Ctek and DIY.
A little advise, be sure to get a good fuse, either replaceable or switched to put on the positive terminal of each battery. The only thing the shouldn't go through a fuse is the starter motor and a winch if you have one. everything else can and should go through a fuse. If you're going to DIY it which will save you heaps then fuses are good insurance against a fire from a shortage.
Ideally you put a 100amp switchable fuse on your positive terminal. then run it to the back of your car where you have a breakout box with fuses for each application, fridge, lights, compressor etc. All fuses should be rated just a bit more than the maximum load the device will draw and all wiring should be rated more than the fuse.
ozscotty
looking at doing the same thing but having the battery's in the back of the Ute, no room under the bonnet. so 100amp fuses at each end, will do. isolator, will do, charging regulator? do i need one will 2 dead flat battery's (if it happens) in the back kill the alternator?
gmatjac
Here's a link to their website of the one i bought D250S DUAL
i nearly bought a ctek 250s yesterday in a shop but i thought i'd check the forum first and see what people think of them, lucky, it was $380 in store, $259 online from ctek
Gavo
Shop around online mate. You'll get it even cheaper.
Great product all the same. Pity about the shops mark up.
gmatjac
yeah i know, i actually went back today to check, i thought it must have been a different model or something to be that different in price.... having said that i did see them for $999 on ebay too
