Dual Battery setup - jump starting the cranker
omvanders
I have a dual battery setup fitted to my Landrover Discovery series 1... the usual sort of arrangement, both batteries under the bonnet, Redarc isolator, fused, heavy duty cable to the rear, multiple outlets, inverter also, etc.
My question is this: In the event that my cranking battery runs flat/crook for whatever reason, can I simply connect my jumper leads from secondary battery to primary battery (the second battery is also an 85AH N70 size wet cell cranker) without having to disconnect the wiring going to the terminals of that second battery?
I'm assuming it's ok to do this but just thought I'd run this by people who know alot more than me,
Obviously I can swap the batteries over if I need to, but this question is more about that quick start out in the bush without that sort of stuffing around.
daweclan
Yeh mate youll'e be fine, Same set up as mine i went crank batt. for auxillary as well for that reason! It's dodgy doing it if you have a deep cycle as youre aux. Iv'e been told it will get you out of trouble but not good for it.Also my aux does my fridge and light at night for three days without a start. Its the same as my start century N70.So from what iv'e heard is all you get from a deep cycle anyway,after the 3 days it only droped to 12.2 V.:)
omvanders
3 days is pretty damn good... I'm yet to give mine that much of a try out with the fridge, lights, etc but if I go for as long I'll be happy. Thanks daweclan.
daweclan
No worries, did you put the redarc in? Tell ya what im'e wrapped with mine,Works a treat,Cuts in and out exactly at the voltage they say it will,And so easy to install,As you say ya need the proper cable,I went 4B&s which is close enough to batt cable ,also inline 100 amp fuses at each batt,and ran an earth between both neg posts on the batts.Showed a auto sparky he said ill'e never have any probs as usually when something goes wrong with them its to do with the earth.He also said when my aux dies,its 7 years old,a freak battery! to go deep cycle/crank in the same batt.there around the same price as a crank. 180.00 He suggested not to go full deep cycle as they wont last,there designed to be used daily,like in a golf buggy etc. where they are up and down all the time not just when you need them for camping etc.Cheers.:)
omvanders
...did you put the redarc in?
Not exactly. My mechanic did, since he knows what he's doing much more so than me.
Yeah, mine's a deep cycle crank as well. I've got it setup for far-west coast fishing trips where you're out in the donga for days on end.
...its 7 years old,a freak battery!
I'm told the main thing is to work them a bit or the plates will deteriorate. I plug my versalite into it pretty regularly while it sits in the driveway, just for that reason. Even so I'll be happy to get 3 years out of it!
frosty
I run a AC Delco 120 ah Deep Cycle. Mines 7 years old and probably last another 7. It cranks the engine easily when needed. (did so for several months when main battery collapsed!!) So long as it is not drained to low often they last for YEARS! I run an Engal voltage cut out on the camper set at 10.5 volts. On the car, the deep cycle runs pretty much everything giving it a constant discharge and charge. No use and over discharge kills them.
bmurray2250
Yes, I have done that a few times on my Prado when the old batteries started failing. I jumper the terminals and you may not need to do the -'ve if it is connected with heavy battery cable between both batteries.
Blue4b
Vanders, check your Redarc for a short blue wire with a female spade connector. If you have one, applying positive charge from your aux. battery to this cable connects your aux to your cranker using your charging leads to jump your cranker.
Check out the Redarc site, it shows you how to do this with a "temporary on" push button in your cabin, allowing instant jump start.;)
Good luck.:)
rodw
Good luck.:)
This is a good idea and ARB did it for me. It got a bit of use today seeing I used the winch three times (only once on myself). I reve the motor, hit the link switch then hit the winch.
Brisey
Something that happened to me to consider is if the cranking battery is dead with shorted cells it can drag down the voltage of the battery you are jump starting from & will not have enough power to turn the starter motor if this happens then you would need to swap the batteries & leave the crook one disconnected.
Bri
Blue4b
Rod, you can also set it up with a positive charge from your winch to the same wire. So when you start your winch it automatically connects your Aux. battery as well.;)
rodw
I worked out what you mean. Clever idea. You'd just want to check it is expecting a current. On Some isolators, you switch the wire to earth, not to power.
Davidman
Go the blue wire option, it works a treat. I have the redarc isolater between my two batteries and have run the blue wire to a ( not sure exactly what it is called ) switch on the dash that returns to one position after being pushed. Just push the switch down, start the car and off you go. You can also run another lead to your dash and attach it to an LED which indicates when both batteries are charging together. All details for the wiring are on the redarc website.
Golddigger
Deep cycles have a thicker plates so can be discharged to 75% of there capacity many times where a starting battery will run the equipment the same time but wont cycle as much. Deep cycle take longer to charge { thicker plate} Starting recharge faster Thinner Plate .
OutBacker
In addition to the discharge levels and recharge rates above Deep Cycles do not like supplying large currents. So I would try to avoid situations where you draw more than C/5. Where C is the capacity of the battery in AH. So if you have a 100AH battery don't pull more than 20A off it for too long. Certainly don't discharge a deep cycle in less than an hour if you want it to last.
Cranking batteries are designed for large discharges and that is why they are rated in CCA Cold Cranking Amps. They are designed for large current draws that are put back into the battery very quickly via the alternator
Brad.
