This may be a little hard to answer but with a bit more information we may find the fault. Can you post what type of isolator that is fitted to your vehicle? What I would do first is to make sure that the second battery is ok so you need to charge it and load test it. Taking that you have a new battery, some of the home made systems which have a solenoid, looks like a small cylinder with two large terminals and two small ones. Need to be mounted the right way up and if mounted upside down after a period they will stop working as the small spring inside fails and will need to be replaced. With your ignition key on you should have voltage on the two big terminals and on one of the small terminals the other small terminal needs to be earthed. If this all checks out so far we are going well, now disconnect your second battery and nothing should change you should still have voltage still on both large terminals if you lose voltage on one of the large terminals you have a fault in your solenoid.
Like I said post what type of system you have which will help solve the problem.
Kruzaman
