Dual battery into 2005 Diesel Triton
hoody
yep no problem, i just done it , i have installed an automatic isolator from the main battery to my 2nd battery in the back of the ute, which i run my fridge of and an engal fridge plug , plus 2 lighter sockets , and an Anderson connection to charge my battery in the camper , when the trailer is disconnected i have a spare Anderson plug that ajoins the one on thecar and i can run my compressor of that and also jumper leads. if you want pics PM your email
big fitzy
yes thanks hoody, pic would be great, email- dfitz67@clearmail.com.au
OutBacker
You could buy the $20 supercheap plastic battery box and mount it in that in the tray next to the fridge.
Given that it is outside, you could run a wet cell deep cycle to reduce cost.
rodw
Got to watch that! Super Cheap wanted $30 but had no lids for them, so I got the same thing at BCF for $19
croozza
will just fit a N50, tight squeeze takes a bit of fiddling around by the look of it
I think if you go the inbetween guards route, the battery would only stick out about 50-70mm into the tub, and you could make up a cover so it cannot be seen.
Golddigger
If its a MK Triton fits Passanger side rear you will only get a 6'' case size [ holden falcon case } should be able to pickup a 60 a/h battery to fit. Should run a fridge for 2 days, easy to fit Talk to BatteryWorld they should be able to help
big fitzy
Hi hoody, the pics would be good, my email is- dfitz67@clearmail.com.au
thanks big fitzy
big fitzy
thanks golddigger, is a 60a/h the same as a n50?
Golddigger
Sorry Mate be offline for a few days yea some manufactures call them n50 but make sure you use a deep cycle or a marine battery. Marine have a plate thickness between staring batteries and cycle batteries so they recharge slightly faster than deep cycle. But still cycle for the weekend use. Hope it helps
