Installed my second battery today, put the red arc on the firewall and bought a deep cycle battery which I installed behind the airbox. All up cost me about 400 I think. Tomorrows job is to run cable for rear power source. What size cable should I use for this?
Depends what your are running. I run 3 sets down the back at once, Battery cable to (bloody huge not sure in sparky terms what size but the copper was 10mm in Diameter) for the anderson plug, 6mm cable as a heavy duty circuit I use that one for the fridge to ensure no voltage drop and I also swaped the factory point in the back to a new cable so it also runs off the second battery.
If your are keen they will all go down the chassis rail at once but it's interesting feeding them down. (3 cans of bourbon If I remember correctly)
I have my UHF, map lights, stereo, fridge points, all my 12 volt outlets and the anderson plug all running off the second battery. I have also set this up as an emergancy start so I can link both batteries by just pushing a button inside the cab and turning the key - good for when the wife leaves the lights on. I run a start battery (not - deep cycle) as my second battery.
I am doing the same job this weekend in my GQ so I can run my fridge etc up at LCMP next week end.
