Geoffrey Hermann
I have a 1999 NL Pajero Exceed model and have noticed recently the deadly two flashing lights that everyone seems to be talking about. I have had a look underneath the vehicle and noticed that the single metal line running into the bottom of the front Diff doesn't have any sort of rubber seal around it. I was wondering does anyone know where to get replacements for them and how you would go about replacing them or best left to a mechanic with the know how. Vehicle is currently sitting in the driveway until above problem is solved as I dont want to cause anymore problems. I have noted that all other selections within the super select 4wd works just wont go back into 2wd. Hopefully the above mentioned is the only problem noting that there is no seal around the pipe thus hopefully not causing vacuum and it is a simple fix.
Any info would be greatly appreciated and hopefully a quick fix. Also where the part might be sourced from
