Downloading Track Files
Davidman
G'day
Tried to download a track file this evening in Ozi (.plt ) format. I got the following. Is this normal, and if so, what do I do with it now.
Thanks
OziExplorer Track Point File Version 2.1
WGS 84
Altitude is in Feet
Reserved 3
0,2,255,ComplimentsOfGPSBabel,0,0,2,8421376
0
-37.821143,145.659017,1,0,25569.00000,,
-37.821784,145.660921,0,0,25569.00000,,
-37.822361,145.662188,0,0,25569.00000,,
-37.823000,145.663950,0,0,25569.00000,,
-37.823582,145.665643,0,0,25569.00000,,
-37.824266,145.666482,0,0,25569.00000,,
-37.824954,145.667534,0,0,25569.00000,,
-37.825243,145.668239,0,0,25569.00000,,
-37.825812,145.668796,0,0,25569.00000,,
-37.826665,145.669561,0,0,25569.00000,,
-37.826280,145.670349,0,0,25569.00000,,
-37.825154,145.670369,0,0,25569.00000,,
-37.824082,145.670104,0,0,25569.00000,,
-37.822673,145.669846,0,0,25569.00000,,
-37.821379,145.669869,0,0,25569.00000,,
-37.820647,145.669883,0,0,25569.00000,,
-37.819975,145.670179,0,0,25569.00000,,
-37.819590,145.670895,0,0,25569.00000,,
-37.819600,145.671817,0,0,25569.00000,,
-37.819389,145.673098,0,0,25569.00000,,
-37.818715,145.673182,0,0,25569.00000,,
-37.818378,145.673259,0,0,25569.00000,,
-37.817932,145.673621,0,0,25569.00000,,
-37.817941,145.674402,0,0,25569.00000,,
-37.817490,145.674339,0,0,25569.00000,,
-37.816768,145.675132,0,0,25569.00000,,
-37.816496,145.675989,0,0,25569.00000,,
-37.816110,145.676705,0,0,25569.00000,,
-37.815784,145.677704,0,0,25569.00000,,
-37.815284,145.678352,0,0,25569.00000,,
-37.814950,145.678642,0,0,25569.00000,,
-37.814059,145.679438,0,0,25569.00000,,
-37.813784,145.680011,0,0,25569.00000,,
-37.813174,145.680802,0,0,25569.00000,,
-37.812557,145.681026,0,0,25569.00000,,
-37.812220,145.681032,0,0,25569.00000,,
-37.811491,145.681329,0,0,25569.00000,,
-37.810869,145.680985,0,0,25569.00000,
bmurray2250
Which track did you download, I can check for you.
I had to download 2 tracks I put up recently after losing my data drive. They ended up with additional wayward points which were meant to be the time markers on the track plus extra track data. Which meant I had to delete the extra items to get the original plot I did. I my case I downloaded into mapsource but can do the OziExplorer also.
Davidman
Hi,
The track above relates to Ellis Track near Warburton. I downloaded three or four others around that area and all downloads came back in the same format.
I have saved them to text files in the hope that I can simply convert the text file to a plt file
Thanks
bmurray2250
Yep confirmed it does that in PLT and GPX formats, ok in GDB format. I saved the text into a file of the same name and correct extension and it worked.
Davidman
Thanks
Have renamed the .txt files to .plt files and they now work as track files in Ozi. Not sure if this is the way it is meant to be, but at least they work.
Brisey
Thanks
The Ozi track files are basically TXT files & the first few lines are the important stuff for Ozi to use, the rest of the lines are positon & altitude etc information. Renaming to PLT is correct. Waypoint files are pretty much the same as well. I find when recieving tracks from mates to my yahoo email account there is no option to save as a PLT file & have to save as TXT then rename after saving.
Bri
jimmbo57
Still stumped
Hi guys, I am having trouble as well. I am trying to save the download but my computer doesn't give me any option to. I have copied and pasted but it on;ly saves as a text file.
I must be so stupid
Jim:)
bmurray2250
That file you downloaded, depending on the file type you attempted to get just change the txt to the file extension you meant to have. Example downloaded as gpx, the track.txt change to track.gpx.
Most units work well on the gpx format but you can use GPSBabel to convert
jay see01
I just found this sorry had post in the wrong spot.
I must be even dumber I don"t know how to do this. Someone pls help me......
Jared Brindley
Hi guys,
I've had a bit of trouble with this too. Downloaded the file, changed it to .PLT and got an error message when I tried to open it in Navigator. Error message was: Invalid numeric input. Has happened on the few files I've been able to try. Am I missing something here?
Cheers,
Jared.
prawns
I dont play with PLT files but.......perhaps check this.....
After saving the file as a PLT file on your windows desktop...right click the file and then click on "properties"
You will get a popup box, in there look for "Type of file: Text document"
If it says that (the "Text document" part) then the extension wasnt renamed (rather the filename itself was renamed and you have a file called xxxxx.PLT.TXT which is still a text document)
If thats the case, I can help further (common issue with people thinking they renamed the extension when they really havnt due to windows settings hiding the extension so it cant be renamed - By default windows is set up like this so its a common issue)
Might help - Might not but its somthing to check I guess
If it turns out it still is a text document.......
Open any folder on your computer, look up the top for a menu which says
"File/Edit/View/Tools/Help" up the top
If those menu items are missing, press the "alt" key and they will popup
Click the "Tools" menu option, then click "folder options"
Click the "view" tab on the popup window which pops up
Scroll down to "hide extensions for known filetypes" and UNtick that box
click apply and close all the popup windows
You can now rename the files extension properly
PJR NSW
Banned
Another way.
Step one; get the text into Word:
With the file downloaded and showing in the acyive window.
Select all the data by pressing CNTR-A.
Put it in the paste buffer by pressing CNTRL-C.
Transfer it to a word document by opening Word and press CNTRL-V.
Step 2: Save the Word file into your Ozi maps folder as a plain old MSDOS text file.
Press CNTRL-S,
Select the Ozi tracks folder you want this track saved in,
Set the type of file to Plain text (txt),
Name the file but with a ".plt" extension.
Click Save,
Select MSDOS,
Click OK.
Done!!!
Print or save this to where you can find it. (ie copy this to Word and save it somewhere).
All those control key functions are still there. They were about the only way of doing things back in the 80's.
Phil
Jared Brindley
Thanks guys!
Prawn: I was wondering why I couldn't change the file type! That was the fix I needed, many thanks!
PJR: Thanks for the reply, I didn't end up using your method as Prawn's worked straight off.
PJR NSW
Banned
Not a problem. It's amazing what the old commands can do. Not the lack of chasing a mouse etc. Cheers
You want to be careful doing what Prawns said. Maybe that second step just sent him your bank details. Shifty looking bloke too.
