Door hinge pins
maddon
i have worn out the door hinge pins to my drivers door on my d22 / i can find pin replacement kits for models up to 2004 on ebay but not the 2010 model that i have / any ideas or should i just buy a pair of complete hinges from a wrecker ---- dunno
muc the truck
if you can do without your d22 while you fix your old hinges , give it a go . I have in the past replaced pins with pins made out of stainless steel that I had a engineer line bore so I could tap a thread in the end and make them greasable like spring shackles . How the hell did you wear out hinges in tis time
maddon
this vehicle has been hammered more than i have ever seen a vehicle punished and it comes as no surprise , even had to remove the front guards / grille etc and reweld the body back together back to the firewall - spider cracks everywhere - still have the fatigue cracks in the guard around the headlight
muc the truck
I unknowingly bought a bogged up Suzuki like that , I had to put 2 mtrs of weld in to the body . I would soften up your suspension to lessen the stress on the body . too many people go overboard on what load they say they will carry and buy the wrong springs . get used to letting tyres down on shit roads . do your bit to place emphasis on vehicle sympathy.
maddon
put on the new hinges and the door works like a new car - changed the oil and filter and it sounds like a newy ---- smiles
maddon
got the hinges from nizz bits / cant remember how much they cost but they were fairly good to deal with and the parcel arrived on time / cant choose the colour though / my vehicle is white - hinges are silver ---- dont care
maddon
i did it one rainy day / its a bit awkward doing them by yourself cause of the wires coming through the door edge
