Don't know which way to store my gear Dual Cab
AussieBrent
Hi Guys,
As I'm starting to get more and more gear that needs storing in my 4wd such as recovery, tools, general things you take on a trip I think the best way to do this would be with a drawer system in the Dual Cab looks good and is neater then just chucking the stuff int he back of the cab.
The issue is when I go camping go and get wood and pile it in the back of the cab and off I go with the drawer system it would greatly reduce the space to collect wood which would mean a trailer would be useful.
I guess in the end the time I go for drives just for the day outweighs the times i go camping with the need to get wood although still nice to have all that storage without the drawer system.
Do you think the drawer system is the best way to go considering the more equipment I'm obtaining.
mac_man_luke
I put drawers in my Ranger around the start of the year.
So far the benefits have out weighted the negatives.
Much easier to keep gear neat, tidy and ready to go with drawers. Less packing up when camping, less crawling into the tray to get stuff.
Yes on occasions it restricts load size but ill either use a trailer or eventually roof racks.
If you dont build them to high you end up with a good size area left.
Gavo
Have to agree. I built a false floor in my dual cab years ago. You cannot beat it. I always just pile wood in there. It's still a ute after all. Full length roof rack works a treat for collecting wood. Beats towing a trailer.
I had made an external roof rack that sits on the outer tub (no drilling through the canopy).. It's a touch bigger than a 6x4 trailer.. Great for collecting time to and storing great.... Just another thought, I will get drawers at some stage....
Godluck
Scottteh
If you're clever, fabricate your own that are removable. A couple of bolts to hold it to the tub, once removed they can be taken out.
I got rid of my home made drawers when I got my ute because they were made of very heavy steel and just weighed a ton. They took up too much room and were not easy to remove (plus due to weight made it hard solo, without pulling them completely apart)
Gavo
Basic is good. 4x heavy duty plastic tubs and you have light, cheap, water proof draws. I have alot more than 4 tubs. Just use tubs I need. If I go camping I put my pre packed camping tubs in. Rest of time I have work stuff. Another advantage is the tubs your not using stack neatly on top of each other. So what you store ykur stuff in you essentially take with you!
03hilux
Have a look at my drawer build on the below link. I only did a single drawer because i use my ute for work and need room for my work gear.
The bulk head end of the drawer also hides my second battery, and a DC to DC charger
The drawer is slightly L shaped to fit around the wheel arch, but also has a narrow side pocket.
I take my work gear out when we go camping, so once the campsite is set up, I can still throw fire wood in the back. ( I leave the fire wood in there over night to keep it dry)
http://www.4x4earth.com.au/forum/d-i-y/14979-drawer-my-hilux.html
LowLux
Gday AussieBrent.
Just happens to be a set of home made, removable drawers, for sale with fridge slide if your interested. You can either pm me or check out the "SA Homemade Drawers" post in the "Spares and Accessories" threads on page 2. The add doesn't show the fridge slide but I will add the fridge slide. Price is neg. have a look at the pic.
nao
I use tubs to hold all my gear in so easy to empty the tray when i want to get wood or take a bike.. tubs work very well and never had an issue with water or dirt getting in them
Johnnie5
and to top it off , if you by the decent ones they last forever even with abuse
and they weigh bugger all compared to drawers
