Does your VMS reboot when starting motor
PJR NSW
Banned
We have a few months old VMS 7000 GPS and integrated entertainment and blue tooth box in the dash.
Scenario: Driving along with the radio, Walkmen input or DVD making sounds as normal and the box displaying Oziexplorer. Time for a nature stop. So you stop and just turn the ignition to accessories and go and find a tree etc. The motor stops but the VMS is still running Ozi and the music is relaxing. You look at the tree and return to the car. The radio is still on and Ozi is also doing its thing. All good. Put the seat belt on and reach down and turn the key to start the engine. Only takes a few turns and she fires up as normal. Love the diesels of today.
However and here is my problem, the VMS box reboots!!! Now I have to reload all those "track to follow file" and waypoint files again. Every time I start the car from the "accessories" position, the box reboots.
Does this happen to anyone else or do I have a faulty box.
Phil
PJR NSW
Banned
Hi Peter
The diode idea will work. That's not a problem. And I have the parts ready to go.
But after thinking about it maybe there is something wrong with the box so why not get it fixed instead of a patch up. Others are saying that it may be a problem as well. It is a bad design error if they left a protection bit out that meant you had to load all your user files, not maps, again each time you started the motor.
I didn't pay all that money to be stuffed around like that. I think that VMS is better than that.
Phil
PJR NSW
Banned
Rats
Read the response to Peter.
Maybe I need to explain something.
The box is basically powered from the accessories power. There is constant power for the clock etc but main power comes from the accessories source. When you start most cars all lights are switched off and accessory power etc is switched off as you turn to the key to the "start" position. Power is returned after the car has started and the alternator etc settles down. This action is removing power from the VMS box and thus it reboots when the power comes back on.
This doesn't sound as if it happened in the old box. Possibly a problem.
It should be fixed if there is an error.
Thanks mate
Phil
PJR NSW
Banned
No good doing the bridge diode thing. There is still a delay between the ACC power going off and the start engine control turning on.
However when I am sitting with accessories running the VMS, if I first turn the ignition to "ON" wait a few ticks and then start the car the box rarely reboots. That's a start.
Anyway this is just a report on my progress. NONE!!!
I have had enough for the moment. Sick of pulling the dash out all the time.
Maybe some time delay like a turbo timer may help but that can wait also.
Phil
PJR NSW
Banned
What happened to the diode idea?:confused:
regards
I got a crank wire and tried it. There is still a gap between the acc going off and the engine start wire turning on. I will try one from the ignition on source and see how it goes.
Not giving up as yet and also keeping in mind that it may be a spike from some where that is doing it.
Phil
PJR NSW
Banned
Fixed. The Battery+ yellow wire voltage is dropping below a threshold of about 10V when cranking. This is the main "permanent" power for the unit.
I cut this yellow wire and connected a fused 12V line from my accessory batteries and all good. I also inserted a diode into the new wire just in case this "jumpering" would upset any car sensors or the Redacr isolator.
This configuration may be an issue if we run the accessory batteries down over a time. But I can engage the Redarc temporarily to get the GPS going if needed.
The bridge didn't work because all the power coming off the ignition switch drops below the "turn off" threshold.
Phil
peterfermtech
Glad you got it fixed (working) Phil but it doesn't make sense. It shouldn't be doing this! If this is the way its supposed to be it would rank with the muffler placement on an X-trail on the list of major oversights.:D I'm surprised no one has come forward offering info on how their unit works.
regards
PJR NSW
Banned
The problem is that we split the two batteries that are standard and are running off only one battery. The voltage on one battery drops more then two at engine start hence the GPS reboots. If I reconnect the two back as standard it works okay. But we run two fridges for very long remore trips so we split them. If anyone is at fault it is us.
People have said they have the same issue privately and just figure that is the way things are. I wouldn't put up with it as I want to use navigation as it should be. Follow track not a bunch of waypoints stuck willy nilly across the map and you may not even see tha next one until it gets on the screen. A line from a mate or made at home is easy to follow.
All good Peter
Phil
hiluxdriver
I leave the car running when I go for a wizz just to save 1 more turn of the starter motor. If it bothered you that much why not consider that next time?
Good to see it was a relatively simple fix in the end.
PJR NSW
Banned
I only used the "tree" walk as an example. There are plenty of other times. Just to have a squiz at a lookout or to grab a drink or pie in a servo/bakery or to help someone who is stuck. What about to change a tyre or have a quick snack. That was a quick collection. There are no doubt more.
I also never leave the car unattended with the motor running. Especially with passengers or the grand kids in the back.
I am going to tray a diode and capacitor and see how that goes. May as well while try it while the dash is open.
It's also not a matter that "it bothers me so much". It is more that it is not right. The car and GPS combination as we have it is not doing it the right way. Why put up with things when you can make it work properly.
I don't like second rate work or patch ups.
Phil
hiluxdriver
I agree, my "patch ups" are still coming back to haunt me. I would have considered taking it back to the installer and getting them to fix it as well, that's what they get paid for.
PJR NSW
Banned
I think that people are missing the point here. I changed the car's battery setup.
It's a Toyota 100 series 4.2td and comes standard with TWO batteries in parallel to handle the starting current and keep the starting voltage up. I split them and thus the single crank battery's voltage drops lower than the factory standard car. Unfortunately it drops below the standard VMS box's threshold by just a measily 1/5 volt.
So the problem is mine because I changed the cars battery configuration. Not Toyotas. Not VMS's and definitely not the installers. If I can find a small 1F electrolytic capacitor at a reasonable price then I have a much neater and safer fix. But they are quite large and hard to fit in behind the dash.
Quite a direct post but I think that you will now understand why it is my issue.
Phil
PS: I am a 50 years experienced and qualified senior electronic technician so I know what I am doing in this field. Just wondered what other say. A man who never listens to others is ignorant. (Please note that I did not say "woman")
peterfermtech
I don't see how it is your fault Phil as the accessories cut power when cranking. The GPS should hold enough power to allow for this until you release the key. Also the electronics within the unit would most likely only be 5v so that it shouldn't need to reboot but only turn off the screen momentarily.
If the capacitor solves the problem then its either a design flaw or fault in the unit.
regards
Phil How about a small relay or even transistor powered by the ignition, with +ve circuit of the relay fed by the Aux battery ( and would sit at about 12.8V) . Most 12v relays will hold down to about 8V so it should stay on. Alternatively an NPN on the -ve side of the GPS would hold down to under a volt as you crank. The +ve of the PS would go to the Aux.
You could use a smaller capacitor with the diode in say the coil of the relay version, somewhere around 22,000uF would probably do it. With a transistor, you'd need a resistor in the base of course but it would be small.
In other words, use the aux as the gate to turn on or off the aux connection. This is how I do my UHF.
peterfermtech
OK. Now I get it.;) Just googled up the wiring diagram. Now it makes sense. You shouldn't need the diode with yellow going to aux battery.
regards
PJR NSW
Banned
regards
Where is the diagram? Send me the link please Peter. Obviously Google doesn't like me.
I am going to try a 1F cap, when I can find one physically small enough to sit behind the dash.
If no capacitor then the emitter follower idea with the transistor would be okay. Better than a relay as there isn't any moving parts. I have heaps of NPN transistors. I used them as switches for the train layout isolation (see activity below in link). I need to make sure that anywhere the two batteries com close to connecting that no "feedback" to the rest of the "other" circuit happens. I don't want the accessory batteries feed anything into the cars computer or any sensors. They have to stay apart. That's why the diodes.
Phil
Switching example: https://www.youtube.com/watch?v=rWvDunfQAQk
PJR NSW
Banned
regards
The accessory power comes from the main battery through the ignition switch. A bit hard to change that unless I use BB's idea of a relay or tranny.
Are there any other power sources or possible wires that lead to the main crank battery? If so the they will also have to be fed from the seconds batteries.
Can you have a look at the wiring Peter and see if any others could possible cross connect the batteries?
Phil
Wouldn't an alternator booster thingy that adds more volts fix this .. or have I lost the plot here :eek::eek: ...????
