Do you carry some form of Fire Extinguisher
What sort of extinguisher do you carry
  • Pressurised extinguisher
    Votes: 58 98.3%
  • Fire Blanket
    Votes: 15 25.4%
  • Water and water vessel
    Votes: 19 32.2%
  • Total voters
    59
03hilux
Whether you are out for a few hours 4wheeling, or camping, do you carry some form of fire extinguisher? Is it an extinguisher, fire blanket, or spare water?
I carry a 1kg extinguisher at all times, and if I go camping, I'll always have a 20ltr jerry can of water as back up.
The water is multipurpose. As excess drinking water, in case the car springs a leak, or to put out a campfire while I pack up camp before departure.
Toddyh
Car based camping I carry just water (usually 2 containers) as I only ever use the little butane cooker. I carry a 1kg extinguisher in the camper because I use the gas cooker there.
MatOZ
I will be investing in one ASAP. Mate nearly lost his Rodeo dual cab when the camping fridge caught fire and had to pull over and drag the mower and unleaded drum out the back. He only pulled over cause the front window between the canopy and cab was black and could no longer see through it. Lucky it was only the fridge burning when he got to it.
eman
Have a 1.5kg extinguisher mounted in the front at the moment, will be adding another one this weekend along with a fire blanket
brumbypt
Banned
Yep I have one that floats around in the back somewhere, probably will hit me on the head if in a roll over. But its easy to grab in a hurry.
dunno where to attach it thats secure and not just a plastic cover.
Peter,
iPad with IOS 7.0.3 using Tapatalk HD
i do in my sports cars but not in the 4x4. Makes sense too tho. I usually have a 2 or 3kg mounted in on the passenger side.
RoughNReady
No but I should. Used to have one mounted on the tunnel of the beetle I had, but not really sure where I could even put one in the Niva. They utilized just about every spare cm of space for something. Perhaps in the back or something.
Traveller
Have one mounted behind my feet, at the base of the seat, doesn't get in the way there. Also have a fire blanket that's usually attached to the inside of the back door.
cookie64
When we did the Canning we each had a 1 litre spray bottle in our doors in case any spinifex got caught underneath, we also had 2 x 1Kg Dry Powder
cheers
BUSHNUT
Carry 2 , 1 in the Cab and 1 in the ute , the fire blanket idea mentioned earlier is a good idea - will get one .
banshee
2 x 1kg one under drivers seat and one in the tray...never used them on my car but have saved a mates car with them before...dodgy electrics
