Do me a favour and check your nuts
smitty_r51
Got a noise from the front wheel this morning on the freeway...thrumming noise that changed speed with the speedo.
straight line and corners, under power or coasting
took it into the mechanics thinking cv or bearings
until he found that three of the nuts were not even hand tight and all the wheels were lose.
check your nuts people!!
TroopiePete
Now see there is your problem!
You should check your own Nuts from time to time :p
Been thinking of getting those yellow pointy things that go over the nuts to show if they have moved, but either way it's worth doing a few walk around tests once a week or on a long trip each morning before you head off..
Maybe yr missus should be checking your nuts for you :eek:
and don't do in public view :D
chris_stoffa
I just had my nuts checked by a professional :D............. all good :cool:
You guess which ones and by whom ? :D:D
75workhorse
Yep had same problem
got new tyres drove a couple of days out 4x4ing in the local forest
low and behold noise under power
found most of the nuts on the wheels were loose tightened them with a wheel brace
seems the lad only used a rattle gun on the wheels and didn't hand tighten them on the ground
always insist on wheel brace tight
80lover96gxl
Had this happend to me on the blue rag range track in vic hc, glad the wheel decided to nearly fall off before the last steep section, 3 loose nuts and 1 broken stud.
underdog
I learnt this very lesson courtesy of mr cloughcarib! Couldn't pinpoint the noise until I remembered his recounted story of loose nuts and losing a wheel etc. Then I checked the nuts... on the one wheel, two were finger tight, the rest were about a 1/4 from falling off. Definitely wouldn't have made it 5km up the road (at 80kph) without losing the wheel :eek:
Respectfully,
Ian.
ratsack
Might check ours tomorrow but I only just rotated the wheels a couple of weeks ago so should be all good. Doesn't hurt to check though and am planning on doing a service on the weekend anyway.
03hilux
Two words... Torque Wrench :)
I spent a fair part of my working life in the tyre game, and a torque wrench isn't always a fail safe.
Nothing beats checking doing a physical check, with a torque wrench, at least weekly. It takes a few minutes, and could save a life
Gavo
I'm waiting for some one to start the anti-seize/grease on wheel nuts and torque wrench debate.
Essentially the difference between a dry nut and thread and one with anti-seize on it is huge. So if you were to measure the pressing power of a bolt dry and lubed one at same torque the lubed one will be far tighter. Hence more chance of breaking stud.
I'm sure someone probably knows exact ratings. But something to consider if you do lube your nuts!
No man ever cut himself bearding!
03hilux
And most vehicle manufacturers say not to lube/ grease wheel nuts and studs.
Gareth4x4
Agreed. But its good practise to use one. Has to be better that putting 300+ FT-LB of rattle gun onto a stud designed to take no where near that load.
rogerazz
Had not checked mine for some time since a mechanic put four extra wheels and tyres on that I bought at his shop. I mean I walk around my truck all the time doing visuals. However since I am going to Bendleby I thought I would do a physical check of my nuts.
Boy, were they tight, some I had to lay the boots into to loosen them. That damn rattle gun he used must have been pretty wound up and being a young strong bloke I reckon his idea of hand tightening was bloody tight.
Anyway, I loosened them all, worried one might snap a stud. Then I hand tightened them in sequence and then I was happy.
However, having driven about 1000 k's since I will now go around them again just to be sure.
I guess with modern cars we tend to think it looks after itself. I have always regularily checked , wheels, tyres, oil, water, brake fluids and a had a general look over the whole truck.
P.S. none were loose but some were real bloody tight.
smitty_r51
yeah if i have the wheels off for whatever reason i usually do mine and then check them a week later in case they have loosened....don't know if I missed them this time, never got back to them ...
but my reckoning it is nearly 9K since they were done, which probably means they are due to be rotated again...
always investigate the strange noises!
millsy
I had a problem with steering vibration coming in at about 65 km/hr last week. I stopped and checked the nuts to see if any looked loose. Nope. Continued on at just 60km/hr to the beach. Then I got the torque wrench out and found two of the six nuts, opposite sides of the wheel, were not tight. Only about 50% torque. Thought that was the problem fixed.
Nope. On way home, sure enough, at 65 km/hr that damn shake comes back through the steering. Then I spotted the problem. Big green light on the dash. It said 4x4! When I had put the gear shift back to 2 wheel drive, I did not quite push it forwards far enough. It had ended up one click short - in 4H!
So front axle was rattling around in its worn bushes, not manually locked into the hubs!
millsy
I squirt some CRC into the nuts before I put them back on the studs. Also a bit on the studs, being careful not to spray the brake discs! That cleans out/off any dust in the threads. I agree that grease is a problem, because just as it provides good lubrication to overcome friction when you tighten the nuts, it also gives an over-tightening effect as mentioned before. And that grease can also cause the nut to loosen with road vibrations.
My theory is that the CRC, being a lot thinner than grease, dries out fairly quickly, or is squeezed out in the tightening process, and overcomes the problem of false tightening against dust in the threads.
I suppose the correct method would be to get a tooth brush and some water and clean off the threads one by one. But I am too lazy for that!
I have been using the CRC method for forty years and have never had a problem with loose nuts.
I think the two loose nuts were because those were new tyres that I had fitted. The chap may have lost track of where he was up to on the tightening sequence. He may have done an initial tightening, and then was distracted, or daydreaming, and missed doing the final two opposed nuts. So I suppose the lesson is to re-check your nuts after getting wheels fitted at the tyre shop. Nothing worse than getting out there, having a flatty, and then finding it impossible to remove your nuts because they were over tightened by a rattle gun!
myall
Lubing does assist with difficult and dry conditions, but I prefer to go without, as it can cause a delay in attaining the required friction point to complete the task. Additionally, whilst it's important to correctly match sizes, sourcing materials which will flex and tension up to the correct specifications will provide more satisfying results over the long term.
*cough cough*
