Les , yes I wasn't going to mention the diff being behind the centre of the front wheels , I have already taken enough shyt over it by some just claiming it's BS , well it's not and it is a real issue with this model Isuzu .
Lifted suspension just makes it worse , there is nothing we can do about the position of the Diff , it's just a PITA ,
Mate, yeah that has been a bit of a shyt fyt on various threads here but . . . I think it's good to recognise and accept things that are bad as well as good with any make / model vehicle, and work with it / change for the better, if possible.
Denial will just see you stuck by the side of a track one day.
If it isn't obvious to people how an offset CV angle forward (or back) could accentuate angle issues, especially with a lift, or at full or near lock, then it's hard to discuss anything with them I guess . . . to me it's just plain mechanical common sense.
Keep in mind, different people won't have the issues depending on where they like to go, what sort of tracks they want ot drive.
Me, I have broken 2 torsion bar mounts on the Ranger, I am certain my north Simpson trips have slightly damage / fatigued these over many km of outback tracks / corros, and eventually went when under future duress and the alst on a very easy track !
I have 2 new ones, will be reinforcing with welded plates before June north Simpson trip, we are driving very ough, much of it untracked terrain, one side to the other.
They won't ever break again.
You could have a hundred PJ/K Rangers drive for decades around the country touring on normal roads / tracks, and not have a single one break / fatigue.
We Ranger owners also have the 4WD module that is seemingly getting more attention on threads with many coming out about their problems, other forums too.
At least we know if this or that happens, we can have a good idea of how to overcome it.
The lockers would help for sure, CVs are also prone to breakage if you get some wheel spin and then it finds ground, or if you hit the brake rolling back down a gnarly track when one is spinning etc.
