DIY Service
ashash132
hello everyone
ive decided to make this tread because I have questions to ask that require some knowledge from people who have replaced/repaired items on there vehicle and hope that it helps other people as well.
being short on money im trying to teach myself how to do simple services so they don't cost you as much when you get them done at a licensed mechanic. i recently replaced my coolant, oil and oil filter in one day and later that week decided to get the rest serviced, hoping to save some money i also informed the shop what i recently replaced. $210 later for a oil and oil filter change i wasn't very happy.
so im asking anyone if they have the experience to help me out quickly
i have a 98' gu patrol 2.8. my AC belt is just about torn apart, brought a replacement and wanted to ask how simple is it to replace it?
also if anyone else would like to add other things you can check yourself to help save money.
Outrage
For the belt, don't know the 2.8 specifically, but in general, old ones are fairly easy to get off, putting the new one on is trickier.
If the AC belt is the very last one you will need to remove every belt in front of it. You might also need to remove the fan shroud, fan and some radiator hoses to have access for tools, etc. General process for removing belts, first locate the tensioner and loosen it, then loosen the bolt the major component pivots on, further loosen the tensioner until you can remove the belt.
The tensioner for the AC is typically an idler pulley system, you need to loosen the bolt in the middle of the idler pulley, then you can loosen the tensioner of the idler pulley to remove the belt.
Getting 'new' belts on requires you to loosen the tension system as far as possible. Then fit the belt as best by hand, likely you will get the belt around the main pulley nicely, but the component it drives you will be lucky to get it half way on. From here you need to get a decent large socket and wrench, and fit it onto the crankshaft pulley bolt, then turn the system with the wrench to 'drive' the belt on the rest of the way, the belt can sometimes twist in this process, just keep turning until it flips around correctly. The main pulley head required a size 27mm socket from memory for my 4.5 petrol.
Then it's a case of replacing everything and retensioning the belts back to specifications.
ashash132
thanks matt. i understand what i have to do now just nervous about stuffing something up, i have one of those repair/rebuild manuals so I'll do some reading tonight and see if that will show me.
prawns
If you manage to get the AC belt off, but cant get the replacement back on again - its still ok to drive to the mechanics without a AC belt installed at all if you get stuck (perhaps a bit of peace of mind, at worst you can still drive it and a mech can fit it)
Any other belts involved would have to be reinstalled before driving first though I believe (this info comes from a mechanical idiot though keep in mind hahahha)
If you go out 4wdriving regularly I suggest you buy 2 of the belts on your vehicle and hoses,my second set is always behind the back seat in the Hilux....
Good luck
2.8 patrol belts are not that hard to replace and you should not have to remove any hoses or related items . As swaggie recommened 2 belts and hoses and keep spare ones in car and also incl spare air filter for when you are going 4 wheel driving .
To do services your self is a great way to learn and be self reliant in the bush in case of a break down .
It can save you money yes but also cost you more money .
Some 4x4s and passenger cars you use the wrong fluids and non genuine parts or carry out a service procedure or repair incorrect it becomes very costly .
I used to happily advice people and go to the point of even writting down various instructions to help them out .
But in most cases these werent followed due to cost of recommened fluids and parts and miss information given by others helping them out with the job costing twice as much money and time .
Alby123
Hi ashash132, I understand how you feel about being nervous. The main thing to remember when doing your own service work is to take your time after reading the manual and kept the manual close by when doing the work. when doing service work on any vehicle there are always things that can be done quicker by not removing all of the components that the manual suggests for you to remove. However this knowledge is learnt over many years. Other than that as I said take your time to do the work properly and do try short cuts at the beginning it may take longer and you may damage other parts when trying to take short cuts. Over time your confidence will grow as you do more work on your vehicle.
Best of luck and believe in yourself. Cheers Alby:)
ashash132
cheers guys, yeah I guess its like one of those things, either pay to get a professionally to do it or save some money to do it yourself but risk damaging something, having the knowledge though will be great to have especially when im 100k's away. i'll see how it goes over the weekend.
