DIY milk crate recovery tracks tested and filmed
80lover96gxl
Not a bad little test there Kam.
How'd the maxxtraxx look after the wheels spinning on em like that,,the lugs worn off ??
We've had better success with sticking them in front of the rear tyres but can see an advantage of placing them at the fronts as the rears get traction as the vehicle moves forward, which could be advantageous in really soft sand.
For a cheap alternative the milk creates can get you out after a bit of manual labour with the shovel.
Thanks for sharing.
hiluxdriver
yeah that was an interesting test. I'm yet to get bogged on a beach but there will definitely be a first time at some point.
I had to mute it after 10 secs though, I like electronic tunes but that was horrendous elevator music.
03hilux
Thanks for sharing. Any recovery tracks are best dug into position so the end of the device is in contact with the tyre. If the 4wd is bellied out, self recovery is more likely if all 4 wheels have a path cleared in front of them as much as is possible.
If the 4wd spins the right rear and the left front, and the other 2 wheels arent spinning, place the recovery aids under the wheels with least resistance.
And lastly, if using milk crates, make sure you have permission. Most milk crates are property of the milk co. and you may be liable for prosecution if not returned.
Aaron Schubert
Great little video mate. If the Maxtrax don't bite immediately, you haven't got them in far enough. Normally people don't dig them under the wheel enough, or they have them angled too steep to work.
A lot of people nick milk crates, but as mentioned above, they aren't free property, and are actually pretty pricey
Aaron
03hilux
Brian, under the rears works better as its easier to push the front out than to drag the rear. Accelerate in any vehicle, and you will notice the rear will "squat" and the front lifts, even under light acceleration.
80lover96gxl
Yep thats why we have always gone rears mate,,ideally 4 would be best, one for each tyre but I cant afford 4 lol.
Iv only got 1 maxtrack, the other is buried somewhere on a beach on the west coast of SA,,Lost when recovering a mate about 5 yrs ago, thankfully never needed them for myself,,yet.
bushlux90
We tried it on the weekend, didnt work lol We got the LC bogged, then i got bogged, then my brothers Scrublux got bogged, then the old internation got bogged lol....What we really needed was a highlift jack, a 5t block and/or a winch
As others have said all traction devices need to be well under / in good contact with the tyres from the start.
Low range second to drive out.
Good comparo, I reckon they all would have been successful first time with more shovel work beforehand.
The Max are good for shoveling anytime I've ever used them, their shape is the next best thing after a spade or long handled shovel.
Even though I use them under the front (when recovering forwards), I dig a lot of sand out from in front of the rear tyres too.
bushlux90
Conquer, shovels are required, especially if your cross member gets stuck. Then your going no where, dad has front and rear lockers and he was the one stuck the most. I had new bfg at's and i got stuck trying to pull him out and my brother had new big horns and he got stuck.
havabigjuan
I keep some hession sand bags stashed in the ute which I have used with success....only get a couple of goes before they are toast though
Def gotta do some digging to help
Always wanted an exhaust jack, I reckon they would be handy in sand recovery
Ziggy
Exhaust jack really needs 3 peeps. One to keep the revs up, one to hold the cone on the tailpipe & another to keep the bag straight & the mats in place as the bag rises.
I reckon a nice big plastic watering can with a shower rose type fitting on it for beaches might be worth a go too.
Fill up from the ocean and sprinkle / dampen the sand in front of wheels after a little shovel work.
Should be able to drive straight out.
Trick is sprinkle to dampen the sand I reckon, too wet and you might have issues, but worth a go.
Just gotta justify carrying a watering can on those beach trips !
MUX STX
I would be worried with the cable ties giving way and then you have a flying milk crate flying out the back.
