Diff ring gears or transfer upgrade
baw888
Hi guys
I have a 75 troopie that is about to get 33s. Maybe 35s.
Okay, i Have the gearbox and transfer apart now getting new bearings and seals.
I'm trying to decide on either new gears in the transfer or new ring gears in the diffs.
The transfer case gears are $1800, the diff gears front and back are $1000.
I can get diffent ratio changes for hi low range gears. Is this worth the extra dollars?
Has any one got these gears in their transfer?
Knudsen
For my part - both
Hi
I run 35" on a camper HZJ (HDJ) 78, and will make both differantialer and transfer. To get as high gear as possible.
It is possible with larger difference between high and low in the transfer which enables the user higher road gearing.
With 1HD FT modified it will be no problem to have significant higher gearing for road use.
All together for a little more mileage out of the tank.
I the thinking department - 1HD FT D4D. (More power with better economics at lower RPM)
Excuse my English Google.
Henrik
Knudsen
