diff locks and left foot braking
fiesta62
hi, i understand diff locks will lock both wheels on a lsd to give traction to both wheels, but i read that by putting a little pressure ( just light pressure ) on the brake pedal while accelerating out will also put power to both wheels , if this is correct then for the average 4wd guy like myself who isnt doing hardcore 4wdriving often, it seems to me that just using left foot braking should do the trick , is this left foot braking idea correct, thanks
Outrage
Your first sentence doesn't make sense, have you typed it wrong?
If you have a rear diff lock, you don't have a lsd. Left foot braking technique is irrelevant.
For a lsd, the left foot braking technique 'helps' but is still far from a diff lock. If your wheels are on the ground, but it's a bit slippery, left foot braking can give a good benefit. If your wheels are off the ground (hole/rocky terrain etc), it likely won't work. That's been my experience, but at the same time I haven't used the technique a whole lot, just the odd time here and there when struggling and I try a few different approaches.
mikehzz
Left foot braking helps on torsen type lsd's because if a wheel is completely unloaded they act like an open diff. When you brake it under power it allows the lsd to do its work by loading the torque onto the unloaded non spinning wheel. There's a lot of info on google re torsen style lsd's as against clutch style. Lsd's aren't diff locks.
fiesta62
hi, i dont have diff locks, i was just pointing out i understand what they do, what i am saying or asking is if the left foot braking is a good or close enough for the odd time i might get stuck, if left foot braking sends power to all wheels then isnt this the same as using diff locks, as u said if wheels are off ground it may not work but if foot is on brake it should from what i read, i'm mostly just going to campgrounds no hardcore stuff yet, i think if i get stuck it will probably be in sand on a beach somewhere, so i thought if stuck air down some more and left foot braking to hopefully move on....
mikehzz
It's a bit of a poor man's lsd and does work to a limited extent on open diffs, but requires practice and finesse to get right. A handy skill if you develop it.
Diff locks will give you 100% drive to all wheels
The left foot braking on an LSD might give you 25 ish % ??? extra drive to the slipping wheel so as has been said is a good thing to do but not in the same category
Difflocks are not of much advantage in sand so wouldn't bother getting them if that is your main usage
80lover96gxl
Applying light handbrake pressure can also have a similar effect as left foot braking.
If you handbrake works well, unlike Toyota ones a few clicks on of the handbrake can also be beneficial.
red hilux
No mate. The closed thing to diff locks other than actually having them is crawl control. ( also has other names depending on car makes)
Left foot braking has no where near the same affect as lockers.
Left foot braking is mainly used on cars fitted with lsd diff to help tighten up the diff, making the diff send power to both wheels. An lsd diff is not as effective as a locker.
When to use left foot braking, bit hard to say. Depends on the situation. You can try it but no guarantee. Also, don't go into places thinking that I can left foot brake as a traction aid
Does your car even have a lsd diff?
