Diesel mechanic?
hypedz
Does anybody know a mechanic in Melbourne (meadow heights) that can come to you for a 1985 hilux diesel?
I drove it home from work and it drove fine, when I went back outside to start it, it just turns over but won't fire, tested glow plugs and glow plug system, all working fine,
Now I need someone to come and see if they can fix it
hypedz
Could a dirty fuel filter make it not start after it was running fine? When I went to start it, it didn't even try to fire
chris_stoffa
A fuel filter from Supercheap and 10 minutes of your time is a whole lot cheaper than a home mechanic visit.
Go for the easy fix first and then you know that it aint the filter if it don't start.;)
ashtown01
My brother has a 2012 model D22, was running fine, parked it then couldn't start it, towed it to Nissan, blocked fuel filter, $110 later it was all good. Apparently shit in the fuel.
chris_stoffa
I changed the fuel filter and it started up first go
Thanks for the help everyone
Good to hear you are back on the track, now try to work out was it caused by a single crappy load of fuel from a particular fill up or was it just a cumulative blockage from multiple fills .
Maybe drain a few litres off the bottom of the tank to see whats in there
