G'day guys,
My Musso's 2.9 litre, 5 cyl Mercedes designed Turbo Diesel (just so we all know what we're talking about) has run on D-Gas for the last 3 years and 75,000 K's (it is up to 103,000 now).
I had the system fitted 2 weeks before I set off around Australia for a year towing a pop-top van. With the Fed and, at the time, State rebates, it cost me $700 which was easily paid off in fuel cost savings within 10,000 K's which was 20% of the trip.
Why did I get it fitted? A mate of mine had a 4.2 litre TD Pootrol done and his Torque at 1,000 RPM was literally doubled. In fact, it was difficult NOT to spin the back wheels on dry bitumen in a straight line off the mark...
As said above, the Diesel system is not altered in the slightest. If you run out of Gas (or decide to switch it off), your vehicle runs as it always did on straight Diesel.
SOME vehicles will accept 30% Gas (by litres) whereas others will ping their heads off at that mix. 20% Gas is closer to the norm in 4WDs. However, the more Gas you can get in there, the better the bang (no, not THAT bang) for your buck.
Working on 20% LPG, and LPG at ½ the cost of Diesel, your average cost per litre of fuel is reduced by 10%. You get about 20% more Diesel economy but, overall, you use the same number of litres of Diesel and LPG as compared to running on Diesel alone.
My Musso runs a smidgen under 20% Gas in normal running around and about 24% when towing the van (because it boosts earlier and longer when towing). In Low Range 4WDing, it'd run about 2% as I am rarely on boost for any period of time.
The Merc TD's are unusual in that they still run 22:1 compression AND a Turbo at 10 PSI whereas most Jap TD's run about 16:1 or 17:1 and more Turbo boost...
In my particular case, I gained 12% more Power and, more importantly, 16% more Torque running on Diesel/LPG as compared to Diesel. Here's my Dyno Graph:
It was about 42 degrres when that dyno run was done, the Musso had only done about 28,000 K's and an intercooler pipe hoseclamp decided to die as I pulled into the place. The dyno had EVERY size hoseclamp known to man except the one I needed... So, the numbers aren't too speccy but you can clearly see the difference between straight Diesel and Diesel/LPG. Actually, I should go and get another run done as she'd put out healthier numbers now...
I have noticed that my oil stays cleaner for longer and, unless working her hard off the line or up a hill with the sun low in the sky and behind me or a car behind me with his lights on, she blows no noticeable smoke. Even in the above exceptions, the smoke is absolutely minimal...
AFAIK, Vic is the only State to have issues with D-Gas vehicles...
I have had absolutely ZERO problems with the system or my motor and expect that to continue for the foreseeable future.
