dieing engine on bumps
damohilux
I have an 07 kun26 series lux, everytime I hit a bump or pothole in the road the engine won't Run properly, I have to let it idle for a couple of secs then it all good. Would any know what the problem is, cos it's slowly getting worse?
Outrage
Sounds like something is loose. Go over the engine bay, I would start with battery clamps. Anything that moves that shouldn't, tighten it. Try that till someone has better advice.
Sent from my GT-I9100 using Tapatalk
muc the truck
If its been beach driven it may be suffering bad earths. This could be a gremlin ongoing but most of the time if its earths a grind off its earth surface and application of some tectyl of crc soft seal over the new earth will fix it for many years to come.
Use lock tight on all bolts you remove.
Mattzz
Check all your electrical plugs...... injector plugs, fuel rail etc. anything electrical.......something is loose.
