Dawes Valve for GU
GuCraig
I was ondering if any of you guys can help with this....
I have a GU 4.2 Turbo Diesel (1999).
A mate of mine suggested I install a Dawes Valve as he did with his 2.8 TD GU.
He had a spare Dawes Valve and with a piece of blue tubing, it took him about 10 mins.
He first set the valve at 16 psi with a compresser which had a pressure gauge.
All seemed Ok, but very occasionally the standerd pressure release valve on top of the engine (crossover pipe) lets go with a loud HISS and continues to hiss until I back off the power. The truck does get along better with this Dawes Valve, especially on the highway, but I don't know about this standard valve hissing!
I was wondering if there is an adjustable valve to replace the standard one or what else should I do.
Any feedback would be great,
Cheers.
Jarh73
If I were you I would take your Patrol to a diesel specialist and let them do it.
Just adjusting the boost is a bit pointless unless you add more fuel. Just increasing boost does very little on a stock engine.
Using a Dawes valve on a 2.8 is incorrect you need just a normal boost controller and again no point adding boost unless you are adding fuel. There is some benefit in getting the turbo to come on boost quicker and holding boost better without bleeding off. This will improve drive-ability but not power.
Best thing to do is get the engine looked at and make sure it's in good condition then consider modifications such as: 3 inch exhaust and dump pipe, full tune of the injection system and then if all is well add some more fuel and boost for a bit more power.
Justin
Jarh73
Thanks for that Justin, I think I'll make a call to Berima Diesel in the morning.
Cheers.
No problem.
I might add I'm not against people doing these things themselves but you need to know what you are doing and if you get it wrong it's going to get costly.
A 4.2 with a few simple mods even with standard turbo will be a good improvement over standard without any real compromise in terms of reliability, engine life and fuel consumption.
Spend the dollars once and do it properly.
Justin
