Damaged Shocker.
BIGCOL
Hi all,
This is an item I posted on another forum last year, I thought it may be of interest to some here.
“When I bought my BT50 nick named the "Beast" I did a number of modifications right from the start to make the car even stronger and better prepared for what I would be putting it through.
One of the main ones was to replace all the suspension with a system designed to cope with the rigours of travelling in the outback and off road tracks that I would be going on.
You can debate what's best but I went with ARBs Old Man Emu System that has been used extensively by many 4wdrivers right across the country. If you read the blurb on the box that the front struts/shockers came in, they seem to be the ant pants and you can see that I chose well.
Well that was still not strong enough for Big Col and where he drives and tows. They come as a single piece, one solid part.
On this trip (I will post that report here shortly) I reduced my heavy duty, strong as an ox, you beaut cope with any terrain shockers to a pile of rubbish.
Here is a pic of the bits that once made up my front shocker.
Col.”
Obviously there is more to this story, and that will be told in due course. Have others destroyed a shocker like this?
Col.
muc the truck
That's pretty typically the result of any brand shock absorber that often hits out of range . I have seen lots of brands do it and its ALLWAYS a result of shockers caging springs under load when the car is airborne or driven on corrugated roads that permit load to come off the springs very suddenly smashing the living shit out of the welds of the shocky . Longer shocks in any brand will fix it . Your vehicle needs all remanning shocks removed while on a hoist to measure droop of the springs . then buy shocks based on that measurement for extension . Do not repeat the mistake by doing it any other way because arduous roads will just duplicate the result you have now . Once you do this correction you vehicle will have more flex. No brand of shock deserves your review . Its not the shocks fault . So many so called professionals get it wrong with lift kits and will fit the existing or the wrong shock to either save a customer money or to shut them up . Its simply not worth it . Maybe if your car never left the bitumen you could have worn the shock out before it ever broke but off road shocks must not cage springs under load EVER.
mac_man_luke
Breaking the lower part of a strut is not uncommon unfortunately,
i did similar to one of my ultimate suspension struts although not as bad on my ranger. They replaced them under warranty but i sold them after that.
I think its partially because no one drops the bump stop when installing lifted/longer suspension which would help quite a bit.
Mono tubes are more prone to it than twin tube due to design but only if they already have leaked oil.
To prevent it happening ever again i installed Radflo 2.5" Remote res shocks (or similar from Fox, King etc)
They have a full billet lower instead of welded parts and are just over all beefier. Was not cheap but i didnt have a single issue suspension wise after installing them and they were like new when i removed them and sold them and the ranger. They also have extra bump stops built in to prevent damage.
mac_man_luke
True to a degree but ARB should have all those details sorted, thats why you pay them good money to develop shocks for specific models.
muc the truck
ITS TRUE FULLS STOP. the wrong shock length has been installed to the vehicle suspension . Full Stop . That's the only reason this happens. Lifted springs on shocks that are simply too short for the job. As I said above some installers will fit existing shocks back on with a lift kit now place that with heavy duty springs its a accident about to happen . If ome fitted the wrong shock he should have had no issue getting it fixed up , lets hope this is the case. But with this post being repeated after 12 months or so bitterness is present.
mac_man_luke
I agree wrong parts will cause the issue but i bet his setup is exactly as per the ARB catalog which should be right but i bet its not.
I bet there is no other options from ARB either, not like they do custom gear.
ARB etc just go on the fact most people will barely leave the black top with there lift kits and just stick something in that will fit, not necessarily right
mac_man_luke
Also down travel on the Ranger / BT50 is limited by the strut from standard and most lift kits. If you have a longer shock like some lift kits the UCAs will hit the strut tower.
I am not familiar with the BT50 suspension setup but if it is similar to the Hilux it is nearly always NOT the result of the incorrect shock length but the result of the lower bush flogging out and you end up with metal on metal and the result is a bent or broken stem on the shock
I know of numerous accounts of this and it also happened to me in the middle of the Simpson desert
BIGCOL
I have no idea why the shocker failed when it did, there was nothing at the time that would have caused it to disintegrate like it did. I at no time inferred that the OME system was rubbish, the bits that were once my shocker (bits of broken metal) were just that, rubbish. ARB paid for the replacement (lab & parts) even though it was just out of warranty. I have been happy with the system over all, it was installed by one of Melbourne's leading and longest operating 4wd accessorising companies. Fatigue? manufacturing fault? caused by some previous wear and tare I have no idea. I was not aware that this is a relatively common experience but I can assure all, the shocker fitted was the one supplied with the lift kit.
Col.
With the Hilux it was not brand specific...... It happened with all brands, in my case I was running Bilstein
muc the truck
Plenty of people have rubbished shocks without understanding why they tear apart . The very first sign is a flogged out bush , bushes should last most of the shocks life if not all . If a bush fails soon after fitting its the shocks length at fault . Bilstiens range only permit 2'' max lift anymore and it will result in a shock tearing it self apart.
Muc I understand what you are saying and in general that may be the case but it is well documented in the Hilux's case that that is not the cause of the failures
The manufacturers even altered their design to having a smaller eye or an offset bush to remedy the problem
Shock length was not the problem in the Hilux's case
This was the previous generation model , don't know what they have done with the latest gen design
muc the truck
Any torsion bar front end at all with torsion bars wound up and extended past what original manufacture say or even some one with a heavy duty set of torsion bars causing a greater lift is going to cause breakage because the length in which the shock was designed for and catalogued against has now been exceeded. No stock standard 4x4 has ever had a constant problem tearing out shocky bushes because the shocks are engineered to the travel .
T
:rolleyes:
Mate they don't have torsion bars and it is nothing to do with the lift height
The problem is the addition weight of winches, bars, batteries and payload overwork the bushes and they need to be inspected/ changed regularly
Hop on to the Newhilux site, it is all documented there
mauriceb
Here another example of a busted shock in the same position of a guy i met in the Simpson Desert 2010. Its an EFS ELite strut. The Vehicle was set up by a reputible 4x4 performace shop in Bris .This Vehicle also bent the Chassis first day out of Birdsville. At the time the owner told me it cost him $7000 for Mt Dare to brink out a replacment strut ordered from Alice and fit it at Western end of the Rig Road
Here another example of a busted shock in the same position of a guy i met in the Simpson Desert 2010. Its an EFS ELite. The Vehicle was set up by a reputible 4x4 performace shop in Bris .This Vehicle also bent the Chassic first day out of Birdsville. At the time the owner told me it cost him $7000 for Mt Dare to brink out a replacment strut ordered from Alice and fit it at Western end of the Rig Road View attachment 37381 View attachment 37380
Was he towing anything ?
I got my shock from Birdsville, he had OME on the shelf, the shock cost me $400 or $600? Can't remember and $1,200 for Barnsey to drive it out to me and bring a spring compressor for us to borrow
Still a lot cheaper than the tilt tray
BIGCOL
Thank goodness I had only 50 or 60 ks to drive to a sizeable town (bitumen) they had to get the shocker courierd in from Canberra. I was towing the van at the time so just took it easy. Total cost to me for the part and fitting was in the mid $300s by memory. ARB refunded that no probs. Glad it didn't happen way out in the sticks.
Col.
sharkcaver
Bloody hell mate, was it Gold Leafed and Gem Encrusted...
No, its called being taken for a ride cause you are in distress and someone has seen a golden opportunity. Don't get me wrong, without these people our outback adventures would be a hell of a lot more difficult, but you cant tell me this isn't blatant profiteering - the law of supply and demand.
muc the truck
That tray looks like its tilting backwards. Is it . Seen a few bent ones like that appears to be
