D40 Navara
NTNavara
I've got a 09 D40 Navara and have done the basic stuff, snorkel, winch, lift kit, upgraded suspension, also upgraded the clutch to an exedy organic with single mass flywheel as the factory clutches are rubbish.
Just moved to NT and aiming to do more remote trips, looking for advice on what other upgrades are recomended, Ive heard the D40 may have issues such as front wheel / diff bearings.
Also the electronic 4wd selector unit, have had to replace this already as after a genuine service the morons at Nissan left the breather tube extension off and it filled with water, corroded away and wouldnt select 4wd, this is still a concern.
Interested in hearing from any other D40 owners and suggested upgrades or problem fixes...
cheers Mike
80lover96gxl
Not to clued up on the navs but what about adding some quality under body bash plates to protect important components, just a thought.
Hi Mike
Sounds like your well on the way to having a capable vehicle. Was looking at the Exedy Clutch yesterday.
Welcome to the forum mate.
Aaron Schubert
Welcome mate,
For remote trips, look at accessories that make your vehicle more comfortable and functional. You don't need any serious modifications to travel remote, but as you have brought up, reliability is paramount.
Do everything you can to make the vehicle reliable, and if you can learn how to do the maintenance (wheel bearings etc) you will be much better off in the long run
Aaron
