D40 - Clunk when clutch is let out
Burra
New to the forum.
I have had the dual mass flywheel and clutch replaced on my D40 (2005, V6) with a Exedy single mass flywheel and HD clutch as the the old DM was clunking and slipping very badly. Problem I now have is there is still a slight clunk when you take off in either first or second once I have just released the clutch, trouble is it does not happen when you do a hill start with the park break, which leads me to think is something to do with the diff.
I had it checked by a Nisan mechanic and all they could say it was because I have changed it from a DM flywheel to a SM flywheel, which i struggle with as I was told the DM was only there to reduce gear chatter and vibration, this was also by another NIssan mechanic.
I'm at the stage that I will get the crush washer replaced and backlash checked as this is the only thing I can think of.
Has anyone installed a SM HD kit? If so, have you had any similar issues? Or has anyone got any advice/solution?
Smitty787
center bearing
Check the drive shafts and the center bearing bush on the rear drive shaft before going for the diff. It may not do it on a hill start because weight is already on these components so it is already hitting what ever it is its hitting. (If that makes sense)
profoto
As I stated in another post somewhere they tend to treat you as an idiot, anyone who does not work there is an idiot, probably the same ones who told me that my D22 does not have ABS.
I simply avoid these fools like the plague, they are so full of crap they could fertilize my paddocks with what they dribble.
Get an independent assessment, it most likely will be cheaper and more accurate.
You will continue to struggle trying to apply logic to their service teams statements.
Burra
Thanks
Gents,
Thanks will check the bearings, and I agree 100% about these dealer mechanics advice. I have owned the my ute since 2005 and not once has the Nissan dealer been any real help.
