D.I.Y winch mount?
RoughNReady
G'day. I found what I suppose could be called a commercially available bumper based winch mount for a Lada Niva, but it seems to be made on an individual basis and would need to be shipped from Europe so it'd be a $$$$ affair. I grabbed the installation instructions off the site to have a look at how it worked and don't see much reason why I couldn't do most of it myself.
Most of it can be fabricated from box, plate and tube. The only real trick part is the winch cradle / fairlead holder but a search on eBay finds generic ones for about $70 which don't look as nice but would serve the same purpose.
Would I be silly for undertaking such a thing? As far as I can tell I have all that I need besides materials, and with a little work I can work out the dimensions easily enough.
It seems reasonable to me but I would like feedback from others.
I'm not sure about putting any pictures of the commercial item up on here, but I should elaborate that it does involve more than just plopping a winch mount on the bumper.
Why don't you just weld a hitch receiver to the front of your bar or rail and you can get access, buy a winch cradle, so it fits the rear hitch and front hitch its not on the vehicle all the time, Carry it around in the back, you then can recover front and back. Just organize power through anderson plugs front and rear, so all you need is a winch for your vehicle and cradle, not much at all.
What is the cost of this method from the UK your talking about. ?...
Tigerz11 Detachable Winch Hitch Receiver - Accessories - PRODUCT RANGE
RoughNReady
I figure I can emulate the UK one... or actually I think it's German given the language of the instructions, for about $200 give or take. That's taking into account buying a premade winch mount with fairlead hole. Optimistically it'd cost < $100 total but I'm usually not that lucky.
There's nothing to weld to. That's what makes the whole thing so interesting. I don't have a roo bar and the bumper is made out of what is essentially really thick C section aluminium. Perhaps 8 or 9mm thick.
Up back it has a tongue type towbar. I've never even seen a receiver hitch style one for them. Pros run for the hills, and rightly so when asked about converting one.
If it did have a receiver hitch and an easy way of attaching something to the front I'd be doing that straight off.
I've seen a few solutions but this bumper mounted one is the cleanest by far. It's a pretty simple idea that essentially involves slipping a couple of pieces of the correct OD tube into the pre-existing bumper mounts, putting a nice solid brace between them which also doubles as some of the mounts for the winch cradle, putting the cradle on top of the bumper and bolting it together. It's a little more involved than that but it's pretty clean.
Some other bumper mount ones don't look very strong, or compromise the bumper to make space for the winch and / or fairlead. There are some other good designs out there too for sure but the way this one worked seemed straightforward enough.
underdog
Will be looking forward to the progress photos for this mod if you go ahead!
Sent from my GT-I9505 using Tapatalk 4
RoughNReady
I do want to go ahead. May be a little while though. This month is a busy one. It shouldn't be all that hard to do.
Gavo
I'd get in there and make it. Satisfaction of 4wd DIY is great. Any one can drive there brand new truck into arb and hand over a years wage.
But making your own stuff is way better.
I like to make a prototype of everything. That's usually the one that I keep. But beauty of diy is you can modify it or change if you need to.
Mate there is no reason at all why you can't make that bar to hold a winch. But I do agree with swaggie. Small car like yours perhaps making a removable cradle would be better option. ?
RoughNReady
It always pays to prototype. I agree.
Removable would be good but it's just not something that could be made to work easily. I mean the basic premise of the design could be modified to put a receiver on it instead but I'd have concerns about all the extra leverage added by the overhang that a removable winch would need.
I attached a photo that I took from the install instructions. It has the manufacturer name on it I think. They won't be losing any money because of me and may even pick up a few sales so I see no harm, because I won't be making more than the one for me.
Anyway what can't be seen in the picture is all the reinforcement inside the bumper mounts and all the stuff going on in between. I chose this picture because it shows how it sits.
RoughNReady
I'm facing a bit of a decision.
I've been after a vacuum pump for ages but couldn't find one online in Australia for some reason. an eBay search yesterday yielded some. All in Brisbane so I'd say a shipment came in and a few people are selling them.
So it comes down to which I do first. Collect parts for A/C or winch. One is to keep the family happy and the other is for utility.
I've been wanting a winch on something for ages. Not just for recovery but for shifting and dislodging things around the yard.
bally
Banned
im not a fan of the slide in hitch receiver winch mounts for a few reasons. 1 they look to be only good for winch straight ahead, if they were winched on any angle it looks as if they would just twist in the hitch. 2 i've seen to many receiver hitches bend from small knocks and basic recoveries. wouldnt want to see what would happen if one broke free under winching conditions :eek:
RoughNReady
I may have raised that concern in this thread. There would be a bit of leverage there which could cause damage with any off centre force.
im not a fan of the slide in hitch receiver winch mounts for a few reasons. 1 they look to be only good for winch straight ahead, if they were winched on any angle it looks as if they would just twist in the hitch.:eek:
Not true, they work very well at doing that, they are no different to a normal winch, I've seen these winches in action, was quite impressed , if we hadn't pulled the vehicle out we would have had to drive 40 minutes around in the dark on steep tracks to pull the vehicle out backwards because it was on the edge of a cliff ..
They are designed so you only put on for recovery, recover and put away if you like, so you have front and rear recovery. Try pulling out backwards with a front mounted winch, it can be done but you need at least 3 trees in the right spot and plenty of gear.
bally
Banned
how do they handle side loads swaggie? id have thought that at least with a conventional winch bar its bolted to the bar which is bolted either side of the chasis and has to try and pull the whole chasis around and would need extreme circumstances to twist it. where as the slide in hitch is only mounted in a single point and can be pulled in any direction from that point?? or do i have the wrong idea?
Ok I get to where your coming from, the conventional bullbar winch can only handle side load only so much, so if it's not slippery it works against the vehicle, I havn't seen one handle it like that, although , the vehicle came down a slippery steep track, lost control on a 45 degree angle and wasnt far from going over a very steep drop off, he had the mother in law in the vehicle at the time. Lmao, they got out asap,anyway no one could get past him to recover, the only option was about a 40 min round trip in the dark and a guy had the hitch mounted winch, had to find a tree and of course its miles away, got the winch extension strap, he hit his remote for winch and bingo, took it off and put it back in his vehicle.
If all happened at about 300metres from the end of the forest, where we were all going home.
RoughNReady
Well it's good to know they are sturdy!
Still not a whole lot of use for me though. I mean I could do a setup so it has a hitch mount above the bumper instead of a winch, but I still couldn't do a rear hitch mount.
I guess that would defeat the purpose. ;)
bally
Banned
i suppose they are more designed for the lighter 4wds too? wouldnt imagine the mount or receiver hitch could handle the weight of a patrol/cruiser?
Sorry mate should have mentioned that too Lol, it was a GQ Patrol..:eek:
bally
Banned
so there a bit stronger then i gave them credit for. good to know if for what ever reason i need to be recovered and thats all that was around
Yeah I think so, only met the Bloke once on a trip, would have been good to get his opinion on it seems its been a few years now.
RoughNReady
I ended up grabbing a vacuum pump as a start on collecting the set for A/C gear instead of any winch bits.
But that's okay. No sense putting the cart before the horse. I have to get measuring and drawing before purchasing anyway. Except for the cradle. That has some pretty important dimensions I need to know like length x width, and mounting hole positions.
