brentons_house
Hi,
I've replaced my clutch with a heavy duty all terrain clutch on the weekend. It wouldn't go into reverse sometime unless pumping the clutch and going into second was crunching. The bearings in the old clutch where rooted and there was a circular scratch marks in the black teeth that point towards the center(don't know technical terms), the clutch plate still looked brand new. Feels heaps nicer changing gears now don't have to push all the way to the floor. Goes into reverse easy now but still crunches in second. I can double clutch going up gears and it goes to second fine but I can't go down into second. I don't know what revs I need to take it to double clutching while gearing down
If I can double clutch into second fine will the problem in the gear box get worse or can I get away without having to fix it?
Thanks,
Brenton.
Thanks,
Brenton.
